Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf1432s washing machine. Barrel not turning.
There seems to be something obstructing the barrel from turning.
The bearings are fine and motor is working.
Does anyone have an idea how to clear the obstruction??
  • Anonymous Mar 21, 2014
    sounds like stones in the drum when you turn it
  • 43 Answers
Take off the sump on the bottom of the drum mybee a hair clip or some thing inside
Posted on Jan 06, 2009
My defy automaid 600 front load washing machines barrel seems to be loose and is knocking against something. How to I inspect it to see what is wrong.
Hi, it could be a few things either drum bearings are needing renewed or drum tension / shocker is not functioning properly.
Jan 25, 2016 | Washing Machines
I have a problem with a fisher and paykel MW512AU washing machine. I turned the machine on as normal, start the load, and everything was fine. After roughly 10 minutes the machine stops doing...
the heating element has an issue
if you say after 10 mins it fails and stops
this indicates two things
the door lock is aok
and the machine fills
next comes heating up the water
some 10 mins into a warm wash
so perhaps the heating element has an issue
or the hardware cant detect it correctly
modern machine detect as they go
however usually but not always a bad element
causes your home electrics tip out...
but as the motor seems to run slow
it could be a sensor or the motor has bad brushes...
Feb 08, 2015 | Fisher and Paykel Washing Machines
Zanussi aquacycle 1200
Sounds like the bearings have collapsed. If you are intent upon doing this yourself check out How to replace washing machine bearings on youtube.
Sep 13, 2013 | Washing Machines
My dryer's barrel will not turn. I have replaced the pulley and belt but that did not fix the problem. The pulley's tension is not tight enough to turn the barrel. I have the correct barrel and...
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
May 04, 2017 | Samsung DV316LES Electric Dryer
It runs fine during most of the cycles except the spin cycle. It is almost like the barrel is not fastened down but i have checked the springs and they all seem strong and tight. When it goes to spin, the...
Could be bearings, the powder is possible Concrete weight / check this is not loose first , give it a good shake/ check for loose securing bolts,,Good luck
Mar 03, 2011 | Washing Machines
The barrel in our LG front loading WD won't turn.
Carbon Brushes on the motor worn down
Pulley loose on the motor or Drum Pulley
Motor control pcb failing to supply enough power to activate the motor
Take your pick !!
Sep 28, 2009 | LG Washing Machines
Neff washing machine - barrel doesnt spin
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Jun 23, 2009 | Neff W4380X1 Front Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Mar 23, 2008 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
175 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
