Question about Zanussi ZWF1430W Front Load Washer
Zwf1432s Barrel obstructed and unable to turn freely.
Something seems to have been letf in pockets which is now causing an obstruction. How can i free the Barrell??
  • Anonymous Apr 13, 2009
    same problem
If the machine displays DE
Posted on Nov 18, 2008
Hoover vacuum UH72511 where is the brush sensor
The motor protection sensor can be triggered by an obstruction or something restricting the brush roll from turning freely. Make sure it can spin freely. If there is hair, dust or debris in the end caps of the brushroll it can restrict it from turning freely.
Mar 30, 2018 | Hoover Vacuums
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Fuji finepix
When a camera notice the lens does not move, it is afraid to damage gears or the motor, of it powers down everything involved the lens. It then gives a message as you read.
Because the camera can't know what is casing this, it only can warn.
It "hopes" if it did run the lens to an obstruction, powering it down will relieve the tension. That is way it says power down.
Remove the battery, check the lens barrel if any obstruction is limiting the free movement of the lens. and then replace the battery. switch it on again.
If you accidentally touched the lens, while it was coming out, it could have given the same error. When after switching on the camera, and you are sure you don't obstruct the free movement of the lens barrel, but it comes back with the same error, you should contact a certified repair centre for your camera.
Jul 20, 2014 | Fujifilm Finepix S2980
Hoover windtunnel V2 Brushes Not Turning
There is a worm gear that turns the brushes, it may be damaged
Aug 18, 2017 | Vacuums
When turning the camera on the lens keeps opening and closing then freezing midway, can't take any photos.
check if you can find any obstruction, that blocks the free movement of the lens barrel. If nothing is visible on the outside, perhaps something inside went wrong. (broken gear?)
As long as the camera finds the lens barrel does not go out to the end position, it will try to get the lens in and switch off.
Also try to charge the battery, because an almost empty battery, can do the same. Although after a few times the camera will not start at all.
Dec 29, 2013 | Olympus FE-340 Digital Camera
Motor hums but doesn't turn all the time.
check for obstruction in blower housing if no obstruction ( sock ink pen lint ball ) replace motor and check for drum rollers and idler pulley they should turn freely
Jan 31, 2011 | Dryers
It doesn't seem to have much power in picking up what can I do
Top of Form
Take the sole plate off and check for blockage and check and make sure the brush is turning freely I suspect the brush is clogged and the soleplate is obstructed. Check the hose for any obstructions as well.
http://www.espares.co.uk/diagram/dyson/dc14-vroom/p/1086/716/0/474352
Nov 16, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
F-54
F-54.. Motor Control Overcurrent. The machine motor controller is detecting high voltage at the motor.
This is usually caused by something lodged between the inner and outer tub. The first thing to do is see if the tub moves freely & smoothly by hand. if not, Then you need to open the top of the machine and remove the splatter guard and turn the drum till you see the obstruction then fish it out. If on the other hand it is free and smooth then there are tests that need to performed to determine the source of the code... Hope this helps... Bill
May 21, 2009 | Whirlpool WTW6600SW Top Load
Zanussi zwf1432s washing machine. Barrel not turning.
take off the sump on the bottom of the drum mybee a hair clip or some thing inside
Nov 18, 2008 | Zanussi ZWF1430W Front Load Washer
Sony dsc w55 when turned on zoom lens seems to be crooked &message tun power off &on again nothing happens
Hello
If the lens barrel is crooked it is normally a sign that the camera has been dropped or knocked.
If you are careful you may be able to straighten the barrel up by trying to push is back into place.
If you are unable to do this you will have to take it to a service centre and have the lens block replaced.
Oct 03, 2008 | Cameras
Zanussi ZWF1430W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
