Question about Kenmore 22442 Top Load Washer
Washer won't stop filling
The machine keeps filling with water regardless of the position of the water level switch. It seems to me that either the switch itself must be bad or that there is some sort of sensor that is disconnected or needs to be replaced. I found a wiring diagram on the back of the machine but doesn't tell me much. Removing the back to access the switch seems to be a task in itself. Thanks in advance for any help or advice you can offer.
  • ttimm Nov 06, 2007
    kenmore 80 washer wont stop filling, I was told by an aftermarket parts reseller that it was either the vacuum line going to the water level switch or the switch itself...can you verify or add your input...thanks
  • Anonymous Apr 27, 2008
    Washer won't stop filling to the point of overflowing to the floor.
Have you tried cleaning the hose that connects to the switch. That was my problem. When I went to clean it there was actually a hole in it. So try that.
Posted on Jul 18, 2007
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Tip
What is wrong when your washer keep filling all the time
Gene
on Jul 30, 2011 | Washing Machines
Water won't shut off at specific load capacity
Good luck, i hope this helps,
Gene
Aug 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How to fix a Kenmore 90 Series when the water keeps running?
Good luck, i hope this will help you to fix your washer,
Gene
Aug 09, 2011 | Kenmore 22422 Top Load Washer
Washer keeps filling with water never shuts off overflows
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking.
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement.
Gene
Aug 04, 2011 | Kenmore 26422 Top Load Washer
When washer fills for wash or rinse it won't stop filling and over flows onto the floor.What do you think it is ?Is it a float problem?
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Roper RAX4232KQ Top Load Washer
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Apr 19, 2009 | Washing Machines
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Kenmore 22442 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
