Question about HP Office Equipment & Supplies
I have a HP 1215 all-in-one printer etc. Have recently replaced the black cartridge when previous one failed to print although not totally used. Replacement printed one letter then ceased to print. Have cleaned cartridges, won't print black part of test page or alignment page in portrait or landscape.
  • 27 Answers
try to clean the print head of that ink with alcohol..coz ink block inside...or wripe print head with tissue paper...
Posted on Nov 18, 2008
B210 Photosmart Plus has HPcoloured cartridges in but is now not printing successfully. Background colour is lavender
Hey, i'm going to mentioned some steps here, follow these as it is:
1. Use Genuine Ink Cartridges
2. Cross Check Estimated Ink Levels
3. Replace All Low or Empty HP Ink Cartridges
4. Check for all Ink Cartridges are properly vented and seated correctly
5. Clean the print-head
Now Start your HP Printer again, i hope, i works fine, to know more, dial my toll-free number +1 (833) 493-0111, Regards
Apr 08, 2017 | Computers & Internet
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Hi. I have replaced the colour cartridge (57) on my 1215 psc but it is failing to print a clear page and the colour is not correct. Thanks
Remove catridge from printer shake well,touch nozzles with tessue paper & see all three cours are visable or not repeat two or three times then chech with printer..
Sep 05, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
Time for a new printer. All inkjets are made to just last 3-4 years. Yours is a 5-6 year old. Good replacements can be had to $100 or less.
Feb 09, 2010 | HP DeskJet 940c InkJet Printer
Just replaced the black ink cartridge on the HP
Take a look at my tip on cartridges it may save you a lot of time and money
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter around on the INTERNET or maybe even local
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 14, 2010 | HP PSC 1215 All-In-One InkJet Printer
Photosmart C6180 will not print in black ink. Have all HP genuine cartridges, although I have used cheaper imitations in the past. Have tried aligning print heads, cleaning, master reset (# & 6...
do not print the printout from the pc.tyr to print a test copy by pressing the menu button on the printer and in that select the option print a self test.then press OK.if the test copy from printer gives proper black colour then its the print setting problem in the pc.just adjust that setting.but if the test page does not print any black line or object that means the cartridge is out of ink and needs replacement.
Nov 29, 2008 | HP Office Equipment & Supplies
The printer is not recognizing the black print cartridge. It is an official hp black 59 (19ml) cartridge but it still does not recognize it and therefore will not print. My printers is an HP 1215...
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml) C6656A HP 57 tri-color print cartridge (17 ml) C6657A HP 27 low capacity black print cartridge (10 ml) C8727A HP 28 low capacity tri-color print cartridge (8ml) C8728A
Sep 24, 2008 | HP Office Equipment & Supplies
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
94 people viewed this question
Ben Johnson
