Question about RIM BlackBerry Pearl 8100
What is the 123 symbol and why d
I have a 123 symbol in a box in the right hand corner of the screen of my Blackberry 8100, and I can't dial numbers, only letters. This has happened before and has always resolved mysteriously. I've searched the manual but can't find an answer.
  • lrachel121 Nov 21, 2008
    I'm having this issue too. I've hit the 'alt' key which switches from letters to numbers and back, but the box in the corner won't go away. Even if it's sitting on the 'number' symbol I still type letters - sometimes dupes!
  • 2,794 Answers
Usually the 123 means that you are in numeric mode on the keypad depending on what program you are on when using the phone. There should be a button on the phone to change the keypad mode from numbers to letters.
Posted on Nov 19, 2008
Keyboard works but cannot dial
I think key pad must be removed to clean contact surfaces.
Sep 08, 2008 | RIM BlackBerry Pearl 8100
Tip
UNDERSTANDING THE BLACKBERRY CURVE 8330
THESE ARE THE MOST COMMON QUESTIONS I HAVE BEEN ASKED IF YOU HAVE ANYMORE I WOULD BE GLAD TO TRY AND HELP:
ADDING CONTACTS TO YOUR BLACKBERRY:
1. TYPE THE NUMBER IN
2. PUSH THE BLACKBERRY SYMBOL TO (THE LEFT OF THE BALL)
3. SCROLL DOWN TO ADD TO ADDRESS BOOK
4. ADD A NAME, CLICK THE BALL AND SAVE THERE YOU HAVE ADDED A NEW CONTACT.
CHANGING THE PROFILE SETTING:
1. SELECT THE SPEAKER IN THE UPPER RIGHT HAND CORNER OF THE MAIN SCREEN
2. SCROLL ALL THE WAY TO THE BOTTOM TO ADVANCED
3. CLICK THE PROFILE YOU WOULD LIKE TO CHANGE (LOUD, VIBRATE, QUIET, NORMAL, PHONE ONLY, OR OFF
4. SELECT WHICH CATEGORY YOU WOULD LIKE TO SWITCH (EX: CALENDER, MMS, SMS, PHONE, TASKS ETC.)
5. CLICK THAT CATEGORY AND CHANGE IT TO YOUR PREFERENCE
COMPOSING A MMS OR SMS TO A PERSON NOT IN YOUR CONTACTS:
1. CLICK ON THE SMS & MMS ICON (MESSAGES SHOULD OPEN)
2. SCROLL UP TO THE DATE
3. PRESS THE BLACKBERRY SYMBOL ( LEFT OF THE BALL )
4. CHOOSE THE COMPOSE SMS TEXT OR COMPOSE MMS WHICHEVER YOU WANT TO DO
5. SCROLL UP TO THE [USE ONCE]
6. CHOOSE WHICH TYPE OF ADDRESS (PHONE OR EMAIL)
7. PUT THE NUMBER OR THE EMAIL IN (WHICH EVER YOU CHOOSE)
8. PUSH THE BALL AND PRESS CONTINUE IN THE MENU OPTIONS
9. COMPOSE YOUR MESSAGE, PUSH THE BALL AGAIN AND PRESS SEND
on Aug 18, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Strange symbol on screen of my blackberry pearl
Generally rectangular box appears when you are in Roaming. After doing the Hardreset still if you are getting rectangular box in your handheld kindly walk into the nearest service center.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
I hope I was able to help you.
Thank you for using Fixya.
Nov 13, 2009 | RIM BlackBerry Pearl 8100
CAP is in the top right hand corner of my blackberry pearl 8100 and I cannot write a number to dial it. I can only dial a number from the address book.
In this case kindly Press the ALT key in your Handheld and the CAP will turn off from your Handheld and you will be able to Dial the number.
I hope I was able to help.
thankyou for using Fixya.
Nov 04, 2009 | RIM BlackBerry Pearl 8100
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
Apr 10, 2009 | RIM BlackBerry Pearl 8100
Typing on my blackberry
It sounds like you have alt or sym function on which is turning your inputs into numbers and symbols. You will have a logo in the upper right hand corner showing you which feature is activated. Turn it off.If you are unsure what I am referring to in turn turn press ALT twice and watch the logo in the upper corner, turn it off and do the same with SYM. You should be able to use your keyboard as normal now.
Feb 12, 2009 | RIM BlackBerry 7290
Blackberry Pearl 8100 - Cant dial a "0"
i suggest sending it back to where u purchased it because there is probably an electrical malfunction
Feb 10, 2009 | RIM BlackBerry Pearl 8100
My phone when I press for automatic dialing it adds a 1 in front of the number and the call wont get completed but if i dialed the number manually it wont add the 1 and the call gets completed. Balckberry...
When you do your automatic dialing, does the number include the area code? ie. mine is 937 (937-xxx-xxxx)
If you don't have the area code put in with the rest of the number, that may be your problem. 1 is the country code for USA, so normally when you see a number that says +11234567890, its country code, area code, phone number.
+1(country)123(area code)4567890(phone number)
So anyway, the only thing I can think of is to put the area code in the phone numbers in your address book if they are not already there. Other than that, I dont know.
Dec 30, 2008 | RIM BlackBerry Pearl Smartphone
RIM BlackBerry  Pearl  8100 Logo
333 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
