I have a Samsung dvd-r136 will not play any dvd. On screen it says disc not recognised check disc. I have cleaned with dvd lens cleaner but made no difference
One of the capacitors been dries out 100%. You need it been fixed by qalified engineer. I fixed mine by replace 2 capacitors on power supply circuit. Their design is silly spetial for rebuyers.
Posted on Jun 23, 2010
I also have a Samsung r136 but have rarely used the DVD player. It went past the warranty and has given up the ghost. It will take discs in but I just get a spinning sound and it won't play anything For a while if I reloaded the tray it would work on perhaps the fifth, sixth, then tenth etc. time. Now it's shagged and won't recognise any disc I put in. Anyone got a suggestion?
Posted on Apr 29, 2010
Most times (90% or more) I input a DVD, the TV screen says Loading, and seems to be processing the DVD loading procedure, but then doesn't play the DVD -- it stays stuck on the Loading sequence. Any...
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 10, 2011 | Samsung DVD-V4600 DVD Player/VCR
My computer does not recognise the disc it keeps on saying i must put in a disc
Please check both of your CD type and CD writer. You may have CD rom with DVD disc cause your computer is unable read the this. If everything is OK, you may have optical lens problem on computer. Please clean the lens with lens cleaner. If problem persist, replace your lens with new one.
Regards, Jay
Mar 19, 2011 | Canon DC210 DVD Camcorder
My Samsung DVD-HR753 will not recognise any of the blank discs I am using including DVD-RW. I've tried Panasonic, Logitec, HP Lightscribe and Datawrite but no joy. I'm trying to record from the HDD to DVD....
It looks to me to be an old machine as I see listings for that model in 2006, now there could be a few reasons firstly it may need a firmware update which will enable it to "recognise discs" made later than it (service engineer).
The laser may be poor, playing is less stressful than recording or it may need a general service, their mechanisms and/or optic slides get dusty sticking to old lubricant slowing response times so the machine goes into "timeout" or just gives up, some have rubber belts which stretch.
It comes down to cost of repair versus new one? you could try a lens cleaner disc (a disc with a bit of fuzz stuck on it) but I have found these have varied sucess and a service clean is better with a suitable liquid.
Hope this helps.........
Aug 28, 2017 | Samsung DVD-HR735 DVD Recorder/HDD...
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
DVD disc is not recognised
itsmylife70, hello.
Two things, Laser gone low and can't read dvd. Just try cleaning the collimating lens with a cotton swab and glass cleaner. gently wet one end and dry residue with the other end.
The other thing is could be just a mutilated loom (flex) cable connecting the laser from the main pcb board. Laser is most likely gone bad.
Good luck.
Apr 04, 2007 | Coby TF-DVD7107 Portable DVD Player
Samsung DVD-R135 / R136 - Will not load blank discs
Hello, First be sure your using the correct disc DVD+ or DVD- RW etc.
I would recomend using high quality discs as players/recorders are very picky about cheap media. Try using Imation name brand discs. They read well in most anything. If it has worked fine & then started having this problem I would first check to see if your using the same discs that have always worked with it & if so then you may want to open the unit & clean the laser lens with a cotton swab lightly soaked in rubbing alcohol. Especially if it has been smoked around or is in a dusty environment.
Feb 15, 2007 | Samsung DVD-R135
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
