Question about AcerScan 620PT Flatbed Scanner
Acer (BenQ) 620 scanner cannot scan transparency
Recently moved scanner to a new computer. Installed the XP driver from BenQ site as Acer no longer supports this 10 year old printer and the scanner division was taken over by BenQ a while ago.
I can no longer select between reflective and transparency images as this menu choice is grey and is set to only scan reflective. I use this scanner for scanning x-ray films (transparency).
I recall that this was also a problem in the original setup many years ago but can't recall the fix(ya) on how to allow for transparency scanning.
    Top Expert:
  • Acer Master
  • 12,962 Answers
Can you put some backing on the transparency and scan it like a regular item?
Posted on May 05, 2017
4 Suggested Answers
SOURCE: Set Parameters Failed
I'm having the same problem with my scanner Primascan Colorado 2400. Looking for a solution I landed on this page.
Website of scanner:
http://support.visioneer.com/products/tools/OS/DesignedforXP.asp
Answers there: nihil.
I bought this scanner some years ago. Worked very well with WindowsME, and until yesterday as well with WindowsXP-SP2 on my overall usually very compliant and compatible modern computersystem.
I used to scan from IrfanView. It always called the scanmanagerprogram very satisfyingly.
But as of yesterday following error-message:
(translated from Dutch) "Can't find entrypoint of procedure _P_ImageDownSample@24 in DLL-file ImgProc.dll."
I've noticed that WindowsXP has two ImgProc.dll's in \system32.
One from the scanner-installation and one probably installed with WindowsXP.
I've installed and reinstalled this very decent scanner several times. And it gets wel detected, without hardware-conflicts.
But, as it worked perfectly before on this same system, it suddenly doesn't anymore.
A pitty.
Maybe I will come back here when I've found the solution if noone else has by that time.
Greetings.
Posted on Dec 02, 2007
SOURCE: ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Posted on Mar 26, 2009
  • 2678 Answers
SOURCE: Acer scanner Prisa 620PT won't work with Windows XP
I can only speak from experience but I have found HP to be one of the best for what you need.
Example here
http://h10010.www1.hp.com/wwpc/uk/en/sm/WF05a/15179-15179-64195-3445112-3445112-3423844.html
Posted on Aug 06, 2009
Recently upgraded my pc to windows 7 from windows xp professional. now my scanner does not work, not compatible with windows 7.. are there any drivers available that are compatible with windows 7
BenQ apparently never updated drivers for this hardware to work un a Windows 7 environment. I do not have this scanner myself, but I did come accross a site that indicated many were having luck with a driver found there. I was unable to test it as I lack the hardware. I do not know it it will work for you or not, but I offer the info for you to investigate to see if you can get it to work in Windows 7. The site is: http://www.bioticaindia.com/benq-s2w-4300u.html
Lastly, if your version of Windows 7 is "Pro" or "Ultimate", it supports "Windows Virtual PC." Windows Virtual PC is a fully *free*, fully functional licensed copy of Windows XP Pro direct from Microsoft that "runs" in Windows 7. You can install applications and hardware in the Vitual PC just as if it were another computer. Follow the Virtual PC link above to learn more about it. You may be able to breathe new life into your BenQ scanner running it in the Virtual PC, if the driver mentioned in the first paragraph doesn't work for you.
Good luck! Please rate my reply "4 thumbs up" if it was helpful - thanks!
Jul 25, 2011 | BenQ Scan to Web 4300U Flatbed Scanner
My driver of my benq scanner 5000B was lost I could no longer use my scanner please help me so that I can use my scanner thank you and hoping for your kind respond.
You can download the Benq scanner driver from this WEB site.
http://www.bravofiles.com/driver-Benq-S2W-4300U_2f3300U-Scanner.html
Jun 30, 2011 | BenQ Scan to Web 3300U Flatbed Scanner
Need Driver under WinXp for AceeScan 340P
For problems with the Acer 620P and probably other Acer scanners in operating systems beyond Win98 (definitely XP), do the following:
First, BENQ now owns Acer scanners. Go to:
http://www.benq.com/drivers/imaging_drivers.html for the new version of mirascan_v3424p.exe. (You can also find it at other download sites.)
Then download and read the installation instructions from BENQ. You'll see a link to installation instructions. From there, click on "How to install my P-model scanner in Windows XP" Or go to:
http://www.benq.com/ss_download/driv...ex_install.pdf
These instructions are the key. After two days of struggle, the above method worked perfectly. The only trouble was I couldn't see the scanner in their last step (refresh step.) I had to restart, and then everything was fine.
Jul 23, 2010 | AcerScan 620P Flatbed Scanner
CS2 CAN'T IMPORT MIRASCAN V342BA
I have a scanner Vuegen scan brisa 620 st
The change computers and operating system I do not support this model
What can I do?
thanks
Jan 28, 2008 | AcerScan 620ST Flatbed Scanner
Acer ScanPrisa 640P driver for Windows XP
I have acer scanprisa 640p.Before i have 98 windows.Now i have in my computer XP windows.Now this scanner is not working in Xp Windows.Pls send me driver of XP.So that i can use in XP windows.I am very thankful to u.My E-mail Is virdi68@yahoo.com.
Dec 10, 2007 | Office Equipment & Supplies
Hi
This Is mayank
I have Acer Scan Prisa 640 P
I need the drivers for my scanner
I have went to the site but i was not able to Get the drivers
Plz send the link to download the drivers
OS : Win XP service Pack 2
Oct 10, 2007 | Acer ScanPrisa 640P Flatbed Scanner
Trouble scanning slides
Just a thought, but the "T" in the model number is for transparancy. When I moved to XP, I had to download a new driver from online but I specified 620UT not just 620U under BenQ. This new interface worked a charm.
Aug 25, 2006 | AcerScan 620UT Flatbed Scanner
Open Questions:
See all AcerScan 620PT Flatbed Scanner Questions
AcerScan 620PT Flatbed Scanner Logo
130 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
