Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
Well its been almost a year that i have been trying to get my tv fixed but no such luck. Zenith repair "center" was here once did NOT fix it and left about 15 screws off my tv casing and never came back. Tryed to call them but all they do is push me away with no answer. I paid over $3800.00 for this set in Oct 03 and since 2005 have been trying to have my set fixed its now Dec 2006 and im $4000.00 in the hole and zenith/lg keeps selling tvs but will not replace my defected unit as well as 100's of others out there.I feel like buying a zenith 60" plasma and not pay for it but i have morals something zenith corp doe's not. Besides they wouldn't feel it but if we all get together in this class act we can do something.
I've had this problem ever since i've gotten my Hitachi...and have had my light engine replaced **twice**...keeps coming back... but my yellow stains are usually at bottom of tv..sometimes creeps to half way up..but then dissapears for a couple days and comes back for a couple days luckily best buy takes care of this because i bought the extended warranty through them...but is getting really annoying... Sony has this problem too..basically its the rear projection's bunk...possibly some sort of gasket problem..maybe due to overuse of the tv...heats up too much and does something to cause yellow discoloration try turning it off whenever you are not using sucks..but if zenith wont help you..u gotta try something... heres the link for sony problem i found: good luck..i'd keep hassling Zenith..and send them all the links you can find about the problem with other TV Sony that is replacing them for people..or reimbursing people if they've already had it fixed
Posted on Oct 03, 2007
  • 65 Answers
Tv needs light engine if you ever replaced one id leave your house screaming too call zenith and tell them you want it fixed free asap dont ever buy a glass panel tv especially zenith the panels are lg
Posted on Dec 09, 2006
0 characters
3 Points
Samsung HCN4226W yello stain around the screen
Its a problem with the screen, Plasma depends upon a chemical and eletrical impluses to create a display... I think you might just want to change the screen.
Jan 10, 2008 | Samsung HCN4226W 42" Rear Projection...
My TV is a Sony Grand Wega KDF-42WE655. I purchased the TV new 5 1/2 years ago and have had to replace the bulb once at the beginning of this year. I have a blue shadow on the bottom right corner on the...
The blue shadow is a sign of a bad light engine. this is a common problem for this model. Fixing this type of problem is quite expensive. Light engine Costs you several hundred of dollars nearly to the price of new TV set.
Nov 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue and yellow shadows appearing on my rear projevtion tv
The convergence IC's are definitely bad. This is not something you can fix yourself unless you know how to solder and are technically inclined.
Mar 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
342 people viewed this question
Top Zenith Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Zenith Projection Television Expert? Answer questions, earn points and help others
