Wireless comunication i have an internet connection through adsl modem with wire, now i want to convert this system to wireless internet communication for my laptop at my home.
  • Jannette Amandy May 11, 2010
    What is the model of the ADSL modem you have? Who is your Internet service provider?
    Novelist:
  • 148 Answers
Greetings my name is Mark and I will be glad to assist you. If you have a cable modem or a telephone broadband you can install just about any wireless router on your moden. I recommend the lynkssys n class router it distributes better and higher signal strength. if you can't afford the n. class router you can always use the g class routers.
Be mucho blessed.
Mark
Posted on Nov 22, 2008
Hello, I am currnetly using a Belkin ADSL2+ modem with wireless G Router and have just been given a D-Link Dir-855 Xtreme N Duo router I wish to use and have been told I can buy a ADSL Modem only to...
I think there is no need to replace the ADSL2+ Router.
Belkin is fine and should work well in combination with the D-Link Router and you would get the downlink data rate up to 300Mbps.
I recommended that you use Belkin Router as ADSL Modem and Dlink to provide wireless access. (Instead of buying ADSL Modem)
So, all you have to do is : -
-Turn-off wireless signal of the Belkin modem.
-Connect the Dlink Router to the Modem (Belkin) through CAT6 Cable.
-Configure the Dlink Router, Secure it and Enjoy 300Mbps Data Rate.
(In this way your Belkin will serve as ADSL Modem and Dlink would be the wireless router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
May 09, 2011 | D-Link Xtreme N Wireless-N Gigabit Router...
My internet connection is slow. wireless home network setup connected to adsl.
is it as slow as when you connect it from the router(not the modem) to your pc with a wire instead of wireless? if so its bc adsl is slow in nature and you may need a filter adapter going into your MODEM first
Mar 25, 2011 | Linksys Wireless-G WRT54GL Router
Modem and Router connected but cannot access internet.
ADSL Modem's LAN -> connect to your Router's Brodband port through ethernet cable.
or
connected through bridging or POP
Apr 02, 2010 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
If I have a wireless router do I still need a modem?
It is depend on which type of connection cable your internet service provider.
You don't need modem if in your router ADSL port and your ISP gives you ADSL but if on wi fi router there not dsl port and your ISP gives you dsl cable then you need modem.
Let me know if you need more assistanse.
Thanks.
Sep 11, 2009 | NetGear WGR614 Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
