Question about Palm Tungsten E2 Handheld
Will not fully charge
Even when charged overnight my E2 shows 'battery low' almost immediately. This is a new problem, for 3 years it has worked well.
  • 13 Answers
Its possible its losing the connection overnight, which could mean its something with the charger port in your phone. Have you tried other batteries or chargers with the device
Posted on Nov 18, 2008
I have ups working in normal operation but indicates alarm " low battery warning " and batteries charge 100% and i cann't rest this alarm
check the condition of the batteries if older that 3 years
the internals expand and split the outer cases
even though they may indicate fully charged , the capacity to run then pc may be severely limited making the alarm show
Dec 04, 2016 | Cars & Trucks
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
I charged the Tungsten E and it doesn't show the charge
I didn't solve the problem. I just can't pay right now. I guess I'll keep asking until I get it solved. I purchased a battery last year I just need someone local ( Denver, Co 800014) to put it in for me. I just hope it will work..
thanks for your support
I truly appreciate what you all do.
Gwen
Jan 26, 2010 | Palm Tungsten E2 Handheld
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Tungsten 2E battery will not fully charge.
Your E2 is showing a battery that is just about dead. Luckily you can replace it
Aug 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Cannot charge new battery
Battery is not a known issue for this model, However 3rd party batteries causes some self discharge issue. Make sure the battery is not defective. The little charge circuit on the battery might have different threshold voltage also. Normally battery should show around 4Volts when fully charged. After save your data try full reset and complete discharge of the battery and try again
Good Luck
Jul 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
My ipod had a low battery, so i charged i overnight as usual, when i got up the next day it said fully charged and when i unplugged it from the usb, it shut off and would not come back on. ive tried to...
I think you may just have a dead battery. The batteries on the iPod last a long time but they do go bad after years of use.
Occasionally a battery will die almost immediately without warning.
Also, use an AC wall charger to verify it's actually being charged.
USB cables work for transferring music, but are a weak source for charging. If you need a battery click here or check ebay they are fairly inexpensive to replace.
Feb 28, 2009 | Apple iPod MA446LL/A MP3 Player
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
