Question about Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range
Garage door wont open
My garage door wont open, I think one of the rods from the lock is bent, when you try and turn the handle it seems to be jammed. Unfortunatley I dont have a side door and my freezer is in there!! Please help
    Scholar:
  • 143 Answers
There really is no way around this. You will have to break something to get in. The easiest thing to do is to drill out the lock bolts or the lock cylinder nad unjamb it or take it off to gain entry. Sorry for the bad news. Thanks BB
Posted on Sep 03, 2010
My garage door will not open but approx. 8" , no cable broken , chain on track. Today I found that one spring is broken. how hard is it to replace.
I have built many garage doors and installed many door openers. The typical garage door spring is not that hard to replace. I have to have 2 steel rods 1/2 inch in diameter to slowly tighten the spring.
Oct 17, 2013 | Stanley Hardware 730610 110 Lb Garage Door...
My door wont open from the inside but will open from the outside
This sounds like it could be one of a couple of things. The rods which attach the door handles to the lock assembly are held in place by plastic clips, these clips break and the rods fall out. You will need to open the door, remove the inner trims and check. If it has, replace the rod back into its slot and put a new clip on it. It may be that someone has tried to force the doors with a slim jim. This can result in the rods being bent or pulled off the lock assembly and can be fixed as above. If this is a rear door, check the child proof setting in case someone has turned it to the safe position. This is located around the lock assembly itself and can only be accessed when the door is open, look on the edge of the door next to the lock for a very small lever and swap it to the other position, then try the door from the inside..
Mar 16, 2010 | 1999 Toyota Camry
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sunburn 1994 handle wont work
Yes, Usually If you pull inside the lock area incorrectly, it will cause the rod to detach from the door latch. The door panel will have to come off and the rod, located and reattached. The retaining clip probably is damaged so inspect it and you should be able to find a replacement at NAPA or local dealership.
May 30, 2009 | 1994 Pontiac Sunbird
Garage door went up..but now wont work
It sounds like the trolley (the thing the door is connected to) is jammed against the bolt just in front of the motor unit. Remove the bolt and then run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it about 4 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Mar 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
