Question about Whirlpool GD5SHAX Side by Side Refrigerator
Water Tube w/ Algae
Any recommendations on cleaning the tube in the door? Ours gets green like the parts of a fish tank and I'm not sure how to clean it out. Gross having green flakes in your filtered water due to the path after the filter the water has to travel in.
  • Anonymous Oct 30, 2008
    I have algae that starts at the bottom of the tube where the tube enters the door and goes all the way to the dispensing tube. We do not have chlorine in our local water supply. Is it easy to remove the tube from the door to clean it out?
    I have a Whirlpool SS25AFXLQ00 Side by Side.
  • 237 Answers
Depending on how far up the growth is, a Q-tip or old fashioned pipe cleaner will do. Typically this is due to the water having the chlorine removed by the filter. I recommend that you remove your filter and install the bypass plug (if needed) and run a few gallons of unfiltered water through the system then let it sit overnight. The chlorine will kill any growth, then you can put the filter back in for filtered water. Usually doing this every few months will keep the "green" out.
Posted on Dec 11, 2006
I had the same problem, I went to the local pet store and got an aquarium filter brush kit, it came with a very fine flexible brush, this worked great. It took some effort to get it around the curves, but it reached to the end and cleaned out all of the algea.
Posted on Aug 11, 2007
Remove algae from GV7070 water tank
Chlorine/bleach - read carefull the instruktion on the back og the bottle. DO NOT USE IT without thinning it with water in the correct dosis! Let it rest til everything is dead. Dont get it in the machine it will be damaged. Do not boil it in the machine! only for use in the watertank. Clean carefully.
May 21, 2014 | Tefal GV7070 Iron
My pond water is very green
Hi toffeegirl1
The green color of your water is due to a high concentration of Algae.
If you have no fish in your pond, you can use some bleach (depending on the size of your pond, use about 2 caps full per 30 gallons) to kill the algae.
If you have fish in your pond, DO NOT USE BLEACH as it will kill your fish.
Please take time to rate me
Bud
Oct 08, 2012 | Garden
I heard that it is good to have dirty gravel in your fish tank. Is this true?
A certain amount of gunk on your gravel is beneficial to thefish. This is because your fishnaturally create an ecosystem based on their ideal environment. Therefore, you do not want to keep your fishtank as clean as the day you bought it. It's ok if the gravel appears slimy or to have a bit of algae onit. You will know it is past time toclean the gravel when a cloudy layer appears just above it.If you want to be exact about it, you can by strips thattest the ammonia and nitrates in the water. This will indicate whether the gravel needs a cleaning.
May 13, 2012 | Fish
Can you clean the clear tube that seperates the UV bulb from the water in a Tetra Green 2 UV?
A test tube brush or a small bottle brush will fit and not damage anything. Alternatively as long as it is not used for saltwater soak in a bucket of 5 gallons water and a 1/2 cup of bleach will kill and separate any algae. Just rinse thoroughly to flush out any leftovers and to clear the unit.
Apr 10, 2011 | Tetra Green Free Uv - 2 Clarifier - 18...
I have a Woods refrigerator that is all fridge, no freezer compartment. Model # RFA17NAC. s/n 07605297JG. It is leaking water on the inside of the fridge and collects on the fridge floor. No manual came...
Hi Linda. We have the identical model of Woods all-fridge and
experienced this problem several times over the course of several
months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs
from the inside rear of the fridge down to the catch tray (underneath
the cabinet, next to the floor, behind the kick-plate) is sufficiently
plugged (with some kind of gunk, probably from a spill inside the
fridge) to cause a back-up. I suppose the inner diameter of the tube is
maybe 3/16" so it can easily get clogged. Consequently, the water runs
down the inside back of the fridge & eventually ends up in the
depressions below the crispers. In our case, after those depressions
filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube
but I didn\'t get it all out. Just enuff to let some of the water get
thru, but the tube would plug up again. After a few repeats of the
problem, separated by a month or 2 each time, I decided a more "drastic"
tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube
completely, but I didn\'t have that available so I had to use a
semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5
yrs. since that more thorough tube cleaning & the problem hasn\'t
come back, so I think the tube got plugged from a spill in the fridge
(which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is
accessible from behind the fridge. I didn\'t pull it completely out
(which might have disconnected it from its fitting), I simply reamed it
out while it was in-place.
Hope this has been of some help to you.
Norm.
Aug 26, 2010 | Woods Upright Freezer MU07W
My filter is returning green slime to the pool as fast as i vacumn it up.I can see it being pumped back in the pool.Why is my filter not working?
It could be that there is algae growing inside the tank of the filter. You may want to vacuum to waste to get the algae out of the pool and clean out the filter. If you have a Cartridge or DE filter, you will need to do an acid bath for the grids. Take the internal parts out of the filter and clean with bleach water, use bleach water on the tank also.
If you have a sand filter, you will need to empty out the sand, clean internal parts and tank with bleach water then fill with new sand.
Jul 14, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Pump is running high keep shocking it, had algae, cleaned it out, back flushed several times, cannot figure out why it's still running high? (unsure of brand)
DE filter? If so then you need to give the filter an acid bath to purge the dead alge from the filter (Fingers, Grids or Discs). Go with 1part muriatic acid to 3 part water. Let soak overnight. The water should turn almost neon green.Rinse off and reassemble. SHould be Good to go. DE and Cartridge filters should be given an acid bath once a year.
Jun 30, 2009 | Pentair Kreepy Krauly Inground Automatic...
Algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
Apr 04, 2009 | Saeco Incanto Classic Espresso Machine
Tools
On the front of the dirty water tank is a block that you pull out(don't forget to put it back in when done, or you won't have any suction), Remove recovery tank front panel
(F) by sliding it straight up.
4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar
toward tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”.
Press round solution tube connector
onto round projection inside door.
Press connector collar down firmly
to ensure that it is fully connected.
The tank replaces in a hingelike
manner. Position front of lid
under tabs (I) on front of tank. Rotate
lid down onto tank.
Make sure lid is secure on all
sides before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove
hose and solution tube.
Raise carpet cleaner handle to
upright position.
Sep 13, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning the water system
A possible solution is depending on your water source... Chlorine will kill the algae, mold & mildew but the filter blocks chlorine. What we tell people is if you have chlorinated water, remove the filter (a bypass device may be needed depending on the make/model) and run without the filter for a week or so. The chlorine will kill all that stuff and then you can run the filter again. If you don't have chlorinated water you would have to mix a solution of bleach/water in a tank of some type and then use a pump (usually a Sur-Flo RV type pump) to supply the pressure and run a few gallons of chlorinated water through the system (again without filter) then let it sit 24 hours to kill the gunk. After that hook up to normal water supply and flush the system until there is no chlorine smell. The ratios for bleach/water, etc. are available on the internet if you "Google" the process.
Feb 02, 2007 | Amana SXD524VW Side by Side Refrigerator
Whirlpool GD5SHAX Side by Side Refrigerator Logo
2,211 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
