Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Jittery picture I have a Toshiba 42H82 that initially had a jittery picture only on start-up. After warming up the picture would stabilize. It is now to the point where the "jittery" picture is constant even after warming up. When in picture-in-picture mode one side does have a stable picture. I had a service call and was told that I need to have the PIP mods replaced (or my hyper module rebuilt). I would like to change the necessary parts myself. Any asistance would be appreciated.
  • Maynard69 Aug 12, 2008
    how much does it cost to have a new hyper modual installed with a new one.Also how much would it cost to have the old one rebuilt?
  • shadeofgreen Sep 15, 2008
    My tv suffers from the same problem....where would you accuire a "hyper module"?
I have a toshiba 42H82 with the same problem of a jittery picture that got worst as time went on. I need to know how can I save on replacing hyper module and do repairs myself.
Posted on Oct 16, 2008
How much would it cost to have a new hyper modual installed?Also how much would it cost to have my old one replaced?
Posted on Aug 12, 2008
  • 65 Answers
The jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Posted on Dec 09, 2006
SOURCE:
Screen rolls and is jittery
If you have room to install extra memeory, do so and see what happens. If you still have the same problem, it could be that your video card is defective.
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
It takes about 5-10 minutes to warm up, then the picture is fine. While warming up the picture wavy and jittery untill it warms up. Is this a picture tube issue?
You have bad capacitors in the power supply or around the 5v & 9v regulator circuits. If you have a meter just measure the outputs of the regulators. If you don't know what a voltage regulator is or does you should call a qualified repair shop. Estimate repair cost $250
Apr 04, 2010 | Mitsubishi VS-60705 60" Rear Projection...
My picture is jittery and goes all over can make out and picture
Ur tv have a convergence problems,it dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Toshiba 65H82 65" Rear Projection...
Toshiba 57h82 "jittery" Screen
I had the same issue and i hooked my time warner cable box up and turned it to an hd channel and it comes in perfect so i set the output to only 1080i and now i can view every channel perfect
Feb 24, 2010 | Toshiba 57H82 57" Rear Projection...
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
Jumpy tv
Hyper module needs to be rebuilt..
Aug 01, 2008 | Toshiba 57H82 57" Rear Projection...
I have Panasonic NV-JF620 VCR and in Australia. The play back is jittery. Few months ago it was working OK. No damage. The picture is coming as small sections and jittery. Audio is ok. Tried it in 2...
Possibly either a tracking problem or the video heads are dirty. Please try a head cleaner which looks like a VHS tape but is meant for removing any dirt on the video head. Most models come with a liquid solution. Tracking normally is automatic nowadays, however, there are some variations and manual tracking (or bt the remote) should correct any jittery images.
If neither of the above is corrective, then your unit would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 20, 2008 | Televison & Video
Toshiba 57H81 Image Problems
Hyper module - need to rebuild them though they are NLA and have been for some time...
Bill
Premium Technologies
premtech@willapabay.org
Feb 18, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
385 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
