Question about HP Office Equipment & Supplies
I changed the black ink cartridge in my HP Officejet K7100 series printer as it was gone and now it will not print anything
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Look in the printer menu for simple errors.
reset the inkt level.
or look if windows "sees" recognise the printer
Posted on Mar 04, 2015
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
HP OFFICEJET K7100 NEW BLACK INK BLINKING
I watch a documentary recently called planned obsolescence and a russian hacker reported finding a chip in his printer that would count the number of print and then lock up once a certain number was reached. This printer was by no means cheap and I was expecting high quality product (something that would last) I think that this printer adopts these malware techniques. The joys of capitalism means companys have zero incentive to offer you products that last. So sick of scumbag corporations
Not to mention how many time I have had to align the printer heads (nearly every time I turn it on)
Jan 17, 2012 | HP OfficeJet K7100 Photo inkJet Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
318 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
