Question about Roper RAS6233KQ Top Load Washer
Maytag commercial washer gets to spin cycle and stops
My washer is 20 years old but mostly used for single person. Just recently it started getting through the wash cycle, and the spin cycle but when it gets to the deep rinse it just sits - makes no sound at all and never moves.
    Novelist:
  • 148 Answers
It sounds like your timer is defective
FIX
When the machine gets to the rinse cycle slowly advance the setting to manually advance the timer
if it just sits bang on the panel or around the knob and listen if ou hear the timer start ticking you will need to replace it
Timers are avaliable from appliance parts suppliers around $29 you can get someone to install it or if you are handy can do it yourself
good luck
Posted on Jan 04, 2009
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Admiral mega 22 plus : knob and spin problems
Rick,
Just call service. Next time you buy a washer or dryer do not shop price! If you have the money to buy a good machine, BUY SPEED QUEEN. IT'S A COMMERCIAL WASHER THAT WILL LAST YOU. THEY CAN DO 8 LOADS A WEEK FOR 25 YEARS.
AND THE BEST WARRANTY IN THE INDUSTRY!
CHECK IT OUT! I'M NOT SELLING YOU ANYTHING. SO DO NOT LISTEN TO THE SALES PITCHES!
Neil
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 05, 2008 | Maytag Performa PAV2200
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
104 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
