Question about Olympus Cameras
I Have an Oplympus C-765 Ultra Zoom camera. Unfortunately the Tripod Socket is Breaking up. and I need a new one, can I get this from you.? It is fixed by two little Screws which I feel I can do myself. How much would this cost me ?
    Sergeant:
  • 276 Answers
To replace the socket check out this link and follow the steps.
Posted on Nov 18, 2008
  • smarttech Nov 18, 2008
    http://astro.umsystem.edu/apml/ARCHIVES/...
    It's easy to get the base off the F2 and put it back afterwards. Nothing
    > > flies apart or falls out. The only slightly tricky part is the
    > > motor drive
    > > socket which needs a two-pronged socket driver. I've accumulated
    > > a sort of
    > > bottomless toolbox over the years and I found a part in there
    > > that did the
    > > trick. When you have the base plate off you can get directly to
    > > the tripod
    > > socket. The tripod socket is a separate small fixture which is held in
    > > place by three screws. Undo the screws and you can easily replace the
    > > tripod socket on its own. You would find a replacement socket at one of
    > > the local used camera stores - there should be one or more in the
    > > Frankfurt
    > > area. If not look in the main amateur photo magazines for
    > > adverts for used
    > > camera stores. You may be able to get a replacement tripod socket on its
    > > own (stripped threads are probably not uncommon) but if not ask
    > > them for a
    > > dead or junked F2 and strip the part out of that.
    Some less well-built cameras have weak tripod socket mounts and can pull out of the camera body causing much personal distress and a very expensive repair, far exceeding the cost of a tripod. The money you save is far from the money you will spend if you break your camera’s lower plate and internal mounting structure.
    Many non-pro camera bodies are made of plastic, even some of the higher priced DSLRs are plastic inside. Unless you go with a pro body, which usually has a metal infrastructure, your camera is likely made of plastic through and through. This trick might be a disaster waiting for a place to happen.
    Also, bear in mind that camera tripod sockets are designed for a compression (downward pressure-and not much at that) load not a tension (upward pressure) load. Again, be careful how much tension you pull on the string.
    A person with even minimal upper body strength and a high tensile strength string can easily place 80 to 100 pounds of tension on the tripod socket and even more. That much tension certainly has enough pull to be disastrous.
My Olympus will not turn on anymore
i think your camera zoom has a dust or sand inside. it cant fully out. stop on/off your camera. bring it to service center.
Jul 11, 2010 | Olympus Cameras
Won't focus when zooming into the subject
It seems that the lense element which mooves while zooming the camera is stucked. normally this happens when the camera suffers a heavy jery, may be by dropping the camera. Resulting into disalingment of the lense assambly. You will need the help of repair shop to solve the problem.
Sep 15, 2006 | Olympus Camedia C-765 Digital Camera
Connect an external flash and aftermarket bracket
For off camera flash with the C-770 Ultra Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable - this cable mounts to the Hot Shoe on the C-770 Ultra Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
External flash
Yes, but only for the C-770 Ultra Zoom. The FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Batteries
The Olympus Ni-MH batteries will provide approximately 200 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are also rechargeable.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
External Flash
A non-Olympus brand xD-Picture Card
Yes, an Olympus brand xD-Picture Card also offers the ability to use the Panorama function.
Conversion lenses
Product Description Stock # List Price Notes M-CON 40 (Close-up Lens) 200 713 $164.95 *Step-up ring (43-55mm) included. WCON 0.7x Wide Angle Lens 200 864 $139.99 Requires 43-55mm step-up ring TCON 1.7x Tele converter Lens 200 862 $129.99 Requires 43-55mm step-up ring
For off camera flash with the C-750 Ultra Zoom, you will need the appropriate flash cable with your aftermarket flash and bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable - this cable mounts to the Hot Shoe on the C-750 Ultra Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Cameras Logo
29 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
