Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator doesn't excite with small power tools.
Briggs and Stratton BSQ 1000 suitcase generator.
I've bought this generator 2nd hand in v. good condition.
If I plug in my hammer drill it doesn't turn or does turn intermitantly.
If I plug in a cement mixer, the generator excites and will then run the drill properly but only if the mixer is running as well!
Any clues?
  • 169 Answers
Somewhere on the Generator is an Idle Control switch, turning this to the off position will stop the generator idling down in the first place. You'll need to do this to use tools that don't draw enough current to trip the idle control system into revving the engine.
It may say just how much current you have to draw in the manual (hint, hint).
Posted on Nov 29, 2008
Swingline model 67 repair
Look on YouTube for videos on how to flash the field on a generator.
Sep 05, 2014 | Electrical Supplies
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
My coleman 5000 generator with a briggs & stratton engine started just fine after years of colecting dust in the shop. After we let the generator warm up we applied a load and found out there is no...
Without knowing the exact model generator you have, it may not even have an automatic voltage regulator (AVR). Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Feb 24, 2011 | Coleman Powermate Powermate 5000W...
I have a 5550 generator and all the sudden the power outlets stopped working. I pressed the reset buttons and nothing. I hooked my electrical device to another generator and it works. What is the problem...
Hello, it sounds like either you have a voltage regulator failure, the rotating field coil is shorted or opened, or the exciter windings have failed. No easy answer because there are a number of issues here as you can see. Depending on how old the unit is you might have warranty. I would suggest you take it to a generac service center to have it checked out. I have 30 years experience with generac units. If it is a voltage regulator issue, (this can be expensive) you can get a jobber regulator. This link is for a good generic substitute. http://www.mcphersoncontrols.com/html/mcp_products/voltage_regulators/MTS63-4.html
I have used this regulator on 4000 watt to 50 kw units successfully. If it is a winding, then to rewind the stator part of the generator is expensive and a new generator is cheaper.
joe
Jan 15, 2011 | Briggs & Stratton Briggs Stratton 6200...
Just bought a generator 5000/6250 style but my husband can't pull the recoil handle. i think it's stuck so we can't test the generator. the unit was shipped from california to the philippines. pls advice...
Try removing the spark plug and rotating the engine by hand.
It could be just a little corroded from shipment over the ocean.
But once you have it loosened up and the oil circulated, it should start much easier.
Make sure it has oil in it, because sometimes they drain the oil before shipping.
You could also have someone else try the starter rope. A new engine can be hard to start.
Oct 04, 2010 | Briggs & Stratton Briggs and Stratton...
How much oil is required for 6.75 hp briggs and stratton engine on a 3750 generator?
Probably about 750cc / near 3/4 of a quart. Make sure generator is on level surface, add oil in small amounts and check using dipstick until shows full.
Jun 09, 2010 | Briggs & Stratton Power Products 5,550...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs and stratton generator keeps throwing the circuit breaker
Power tools CAN draw heavy loads if the voltage or frequency is off. Both of those CAN be a fault of the generator.
Check the frequency by plugging in a clock with a moving second hand and time it for 10 minutes against a quartz clock. ALSO do a voltage check with another voltmeter.
The 5500 Watt generator should hold 40 amps. Power tools with induction motors like some table saws take a large starting load near this value AND would be sensitive to low voltage AND especially low frequency, both of which will cause much higher current draw.
One MIGHT have to resort to put an oscilloscope on the output to make sure the waveform of the AC output is normal..
Apr 03, 2010 | Briggs & Stratton Power Products 5,550...
No power output
Hi, check your exciter cap inside the control box as it probably is knackered, Replace it with a new one.
Or if the unit was severly overloaded the windings are probably fried.
Oct 21, 2008 | Briggs Stratton H7159 & Stratton® 5500,...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
500 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
