Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the Imac?
    Genius:
  • 1,269 Answers
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Posted on Dec 19, 2008
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Cable company says modem is working problem is
If you have internet access trought the modem and if you're not connecting to the internet with the router it might be a configuration inside of the dlink router.
Usually tech support wont help you with the routers.
but i can help you with this.
http://register.wireless.utoronto.ca/?page=dlink
if the connection its set up and the wireless signal its not strong enough yes you'll need to replace the router, that's what happened with mine :S.
The signal was really weak.
Apr 27, 2010 | D-Link (DI-711) Router
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Cable internet setup
No, you need to buy a wireless router and connect wireless router to cable modem. Non cable modems do not work on cabled wireless network.
If you buy cable router, buy either a router with no modem integrated or a modem/router for cable network, this last one may be best option, but it needs to be configured. Ask to retailer which models are ok with your broadband provider.
May 24, 2008 | Computers & Internet
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
435 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
