Question about Nintendo Wii Console
Some Virtual Console games don't work!
I recently bought new TV - a True HD Panasonic. I use a component cable to connect my Wii to the TV, with the HDTV setting turned on. When I wanted to play some of my virtual console games, a few of them didn't work, especially I noticed that the NES ones had the most problems. I could see the graphics on the background with the 'Home' menu active, but going to the game, I just saw a frozen gray-green image, nothing moved, or anything. The sound was on and when I pressed the 'Home' button again I saw that the game was actually working (the screen 'background' changed), I just didn't see anything during gameplay, rendering the game unplayable. Some games work just fine (Bomberman 93'), but ironically most of my games are NES...I live in Europe, so my TV is PAL.
    Problem Solver:
  • 5 Answers
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Posted on Feb 19, 2009
I bought Super Mario Bros. 3 from the Wii Shop Channel, but when I attempt the play the game the screen just goes black and all that's left are the words "invalid format." Also, the TV is an...
Hello.
Here is what it says in Nintendo Wii SHop:
Some newer-model televisions may have difficulty properly displaying some Virtual Console games downloaded from the Wii Shop Channel. If you are experiencing problems (such as a blank screen but you can hear the game's audio), please try the following:
    Try changing the way your Wii console is connected to your television. For instance:
    • If the Wii console is connected to a VCR or cable box, try connecting the Wii directly to the TV (how to).
    • If the Wii console is connected to the TV directly, try connecting it to a VCR (how to).
    • If possible, try connecting to another TV.
    If any of the above are successful, it is recommended you use the connection that works. If the Virtual Console game still did not display properly after trying different connection types, please call 1-800-255-3700 to discuss available options.
Aug 03, 2011 | Nintendo Wii Console
Tip
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
on Mar 04, 2010 | Video Game Consoles & Games
Can i use a normal over the counter HDMI cord or is there a "special" Wii HDMI?
Hi, the Wii does not strictly have an HDMI connection but the closest thing to it is a Component cable. This has 5 connections and is as close to HD as you can get without a full HD connection. Make sure your TV has component connections on it as well if you do purchase one. They can be bought for around £5 off of places like ebay.
Hope this helps
Dec 06, 2010 | Nintendo Wii Console
We bought a new samsung 32" flat screen TV. Our HD cable box is connected to the tv using the red/yellow/white cables. Is there an alternative way to connect my Wii without unplugging the HD box...
You'll need to purchase an HDMI cable and use that to connect your hd box to your tv. Your tv should have several HDMI connections on the back to facilitate the hookup and you will not have a true HD picture without that cable. You can buy this cable from the same place you bought your tv or www amazon.com as well as many other electronics supply stores, hardware stores, or places like Kmart, Walmart, Bimart, etc. You can also buy a multi port Rh connector box that you can run multiple components through and just push the corresponding button for the component you wish to operate.
Hope this helps and please rate my solution!!
Nov 27, 2010 | Nintendo Video Game Consoles & Games
I just bought a new plasma tv. I cannot seem to
You Plasma TV is probably an HDTV, which means you need to change the settings on your Wii to HD. Just go to the Wii menu and modify the TV settings. If you don't want to do that, make sure you connect your RCA cables to the non-HD slots on your TV so that the yellow RCA cable is in the yellow slot and not the green HD slot.
Dec 17, 2009 | Nintendo Wii Console
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Hd connection for wii
The red and white ones, that should be linked or the same are sound.
Dec 26, 2008 | Nintendo Wii Console
Wii component cable - how to connect it?
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Oct 14, 2008 | Nintendo Wii Console
Screen Jumping
Try and adjust your screen frequency in the wii system settings.
Mar 26, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
530 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
