Question about AT&T Lands Phones
Upgrade memory chip in at&t 1725 answering machine?
I'd like to upgrade the memory chip in my at&t 1725 answering machine to one
with a larger memory.  it uses a non-volatile chip, but i have not opened the unit
to see which one.  if someone has the schematics and can email them to me, or
just knows what chip it is, then i could try searching the web to see if i can find a replacement.  or, if someone knows that info already, that would be even better.   the current chip holds 24 minutes, and i'd like to up that as much as i can.  newer answering machines hold about 40 minutes, but are so far either much
harder to use, or lose all settings and messages when the power goes out.
    President:
  • 2,992 Answers
Typically no schematics are ever available for this kind of product as nobody - even the manufacturer - expects to repair them. They are strictly throw-away. But you could open it and try to get the part number from the chip, then search out a suitable larger-capacity replacement. Problem is that almost everything now is surface-mount devices which you probably wouldn't be able to remove and replace without appropriate rework tools. Sad to say, replacement might be the best option.
Posted on Nov 19, 2008
How do I upgrade memory?
By adding more similar memory chips in the spaces, if any, provided on the mother board. If no room substitute larger chips according to mo bo specs.
Jun 14, 2015 | Computers & Internet
Att 1725 answer machine, what is powerpak output voltage?
You will probably be able to find that on google search
Jun 06, 2015 | Lands Phones
I have lost my Manual for the AT&T 1725 answering Machine. Can you mail me a new manual? Send to Burnley Miles, 5325 Calvin Court, Colfax, NC. 27235
Retrevo has the manual for the AT&T 1725 here: http://www.retrevo.com/support/AT%26T-1725-manual/id/473bh046/t/2/ . You will need to enter a code to download the PDF. Adobe Reader or a similar program is required to read the file. You can print it out yourself or take it to a print shop.
I hope this helps.
Oct 26, 2011 | AT&T 1725 Answering Machine
How can I retrieve messages accidentally deleted?
Look for the manual of your AT&T 1725 digital answering machine
Jun 26, 2010 | AT&T 1725 Answering Machine
On Model 1725 get message F1, how do I clear it, etc? John
CLICK HERE for your owners manual in PDF format.
F1 indicates a communication failure with the digital EEPROM (onboard memory).
Essentially you have a paperweight now.
The repair requires a replacement of the memory module, and from all accounts, that proprietary part is not sold.
I would also assert the repair to cost more than another unit (new, or used)
Thanks for using FixYa!!
Sep 03, 2009 | AT&T 1725 Answering Machine
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
AC ADAPTOR (power) for AT&T 1725 answering machine
Radio Shack It Just Needs The Same OutOut Voltage It Should Say On The Bottom Or On A Tag Somewhere Output 9v Or Whatever
Jan 05, 2009 | AT&T 1725 Answering Machine
Lucent Technologies 1725 answering machine
Taken from the 1725's User Manual:
Deleting Messages
1 Connect with the answering
system.
2 To delete selected message
— Press
and release 3 while the message is
playing.
To delete all messages in a
mailbox
— After you have listened to
all messages and heard the two beeps,
press 3, and then the mailbox
number.
You can download a copy of the manual at the following URL:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=164
Jul 15, 2008 | AT&T 1725 Answering Machine
Lands Phones Logo
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
