Question about Xerox Phaser 8500/DN Printer
Error code 09,036.44:65009
Does anyone know what this error code means HELP.?
  • 276 Answers
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Posted on Nov 18, 2008
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If after following smarttech's advice you decide you need to replace the ink loader, the part number for the 8500 is 133K27711. Here is a video that shows you how to replace it. Also covers the 8400, 8550 and 8560 though the part numbers are different. Good luck, hope it helps.">
Posted on May 26, 2011
We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
OBD Error Codes
I get an error code of 052 on the A/C control unit in my 2000 Mercury Grand Marquis. Does anyone know what this error code means?
May 26, 2010 | 2000 Mercury Grand Marquis
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Code C:31:23
Already replied.
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Xerox Phaser  8500/DN Printer Logo
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
