Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Dishwasher not draining and 3 lights are flashing
Turn the dishwasher on and it filled up with clean water and leaked on the floor so i switched it off and back on again now it wont do anything and all 3 lights are flashing. help
  • 944 Answers
Check this thread for starters http://www.fixya.com/support/t135923-dishwasher_beeping the solution to the leak would depend on where you think it is leaking from - usual areas to check are the door seal, door latch, inlet and drain hoses and where they connect, the base especially towards the back. also make sure the drain pipe the dishwasher is connected to is not blocked - sometimes leaks from in the machine can be traced to this cause. Hope this helps, post again if you find anything and hopefully we can help more :)
Posted on Mar 14, 2007
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
Dishwasher will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 18, 2008 | Dishwashers
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
Model No. DU850SWPU3 AND SER. FT 4101406 TYPE 280-0. When cycle is complete and in off position the dishwasher fills with water. I find the bottom of the dishwasher standing full of water when I get...
If by turning the wall switch off, and only then it stops comming in, it means the board is faulty. There is a leak in the electronic system allowing to solonoid to stay partially open. Strangs that it doesnt flow onto the floor.
Aug 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Water leak at back of ice maker ,made big ice ball at rear of tray then ran out on floor. Turned off water ,cleaned out ice now wont do anything .. Tray wont fill , rack dosent move.Was making ice good...
sounds like you have a bad water valve solenoid. check the ½" diameter fill tube that feeds the water into the fillcup of the icemaker, you may have to remove the icemaker to see inside. is this tube frozen with ice? if it is, you have a bad solenoid.
Feb 15, 2010 | Refrigerators
My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Feb 11, 2010 | Dishwashers
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
191 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
