Question about Epson Stylus C60 InkJet Printer
Change ink colour
How do i change the coloured printing to black when i am printing on my pc
Anne Johnson
  • Epson Master
  • 541 Answers
In you need to go in to the printer setting
Posted on Nov 18, 2008
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Need to print black only but low colour cartridges cause error
Most likely you cannot. If you do not have any of the colour cartridges with ink in them, the print heads will dry out and when you want to print in colour you will not be able to print in colour.
Feb 02, 2012 | Canon Office Equipment & Supplies
Black colour is not printing
When you print in color is does it show black ink?
Sep 23, 2010 | Office Equipment & Supplies
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus C60 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
