Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
No audio sound after installing the keyboard software
I ran a problem after installing the keyboard software. When I play music, there is no sound. Uninstall the software and were able to hear sound.
  • 3 more comments
  • chao_xyooj Nov 18, 2008
    The mute option on the keyboard is off, but still no sound.
    Im running vista 64. The keyboard is compatible with vista. Im not sure if running the vista 64 is the cause of the problem.
    I can control the volume bar with the keyboard, but there is no sound at all.
  • chao_xyooj Nov 19, 2008
    Problem fixed!!!! thanks
  • sheryl0513 Nov 26, 2008
    I can not play any attachement that has sound on my PC ever since my wireless MX3200 was installed. How do I fix it?
  • scottmcgee Dec 06, 2008
    I have a system that runs Windows XP Pro sp3. My sound worked perfectly until I install my MX 3200 keyboard and mouse today. Now, no sound. I checked the sound setting in Control Panel, they look fine. I open my volume control, and it looks fine. The keys on the keyboard (as well as the onscreen controls) work fine to change the volume and turn mute on and off, but no sound.
    I did update the version of the software from the web. No change in sound.
    Any ideas?
Greetings, I'm having the same problem here with my keyboard output not working. I used the MX 3200 keyboard+mouse combo for several months until it recently stop working properly. This may seem weird but sometimes if my desk is hit (either by my foot/arm, etc.) I start to hear ticking/"fuzz" noise coming from my speakers (even if they are turned off!) for several seconds and then my mouse and keyboard stop responding to input. This also randomly happens when I'm on the computer for several hours at a time (gaming). Until recently, all current attempts to connect my keyboard have failed and I'm stuck clicking on the on-screen keyboard. I also have a logitech USB headset which also stops responding to sound when the keyboard/mouse combo stop responding. I have tried uninstalling my current SetPoint software and no change has occured. Perhaps I have missed something or my drives need updating. Any help would be appreciated.
Note, restarting my comp. usedto solve the problem tmporarly, now it doesn't anymore.
I am using Windows XP Home Edition Service Pack 3. I have no idea where to or how to change my sound card device as the ocation pointed out is a bit vauge :\
Posted on Dec 29, 2008
The problem is that the SetPoint software change your PC's default sound device to a bluetooth device from your original sound device. Go to control panel -> sound device setting and then change back the default device to your original sound card device. You will be fine.
Posted on Dec 17, 2008
  • 903 Answers
When you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Posted on Nov 18, 2008
  • 1 more comment
  • Debs
    Debs Nov 18, 2008
    what version of windows are you using? If you are using vista, is the software vista compatible?
  • Debs
    Debs Nov 18, 2008
    When I loaded the software for my Logitech keyboard, the sound was barley audiable. What I had to do was turn down the sound using the keyboard, the key with speaker - sign, then manually turn my speak up. Then when listening to music I can press the speaker+ sign on the keyboard to get the desired volume.
    If this does not work for you then you may need to get updated software for your version of windows.
    Let me know
  • Debs
    Debs Nov 18, 2008
    okay because you have vista 64 the cd version may not work correctly, try going here
    http://www.logitech.com/index.cfm/403/&a...
    select your keyboard and download the software from online
    This should help you resolve your problem
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
How do i connect my midi keyboard (yamaha PSS-51) to my personal computer and play from keyboard through to the pc? Do i need an installation cd? Please help me. Thanks
Maybe read the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-PSS-51-Music-Keyboards-manual/id/961ci070/t/2/
If your PC supports MIDI, its hardware/software would have some guidance and settings. If you just want raw audio to play through the PC as analog sound just jack the keyoboard into whatever sound input you ahve that supports an analog input. See page 5.
For just listening, any audio device with a headphone/earbud/RCA output can be connected to any available analog Line Level input (except PHONO) with a simple adapter.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
May 11, 2011 | Audio Players & Recorders
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Mar 01, 2011 | Music
Try to get the keyboard to play through out my speackers
Since this has no audio output it will depend upon your computer to generate the sound using the audio system in the computer. You will need the driver software for the M-Audio to talk to the sound hardware in your computer and configure that to accept the MIDI inout from the M-Audio.
You will need to OPEN the volume and mixer controls for your sound board, unmute it, and enable the SYNTH channel and select "general MIDI".
As a test, download VanBascoe's Karaoke thing and play MIDI files to make sure your synth software is working. Then assign the MIDI source to teh USB input from the M-Audio.
Nov 01, 2010 | M-Audio Oxygen 49 USB Midi Controller
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
Sound card?
this could be a result of the software malfunction ...i'm talking about i-tunes,if your computer plays other sounds,it clearly shows that its not a problem with the sound card which is nothing but the hardware for playing sounds in the computer.
for further clarifications revert on this page.
Jun 13, 2009 | HP (400745-001) Sound Card
Audio Problems
You have a failing hard drive
Jun 02, 2008 | HP Pavilion dv8000z Notebook
Problem with "M-Audio 49e keystation"
Buy a Mac, Then you won't have that problem.
Oct 21, 2007 | M-Audio M AUDIO RADIUM USB KEYBOARD...
No Sound when I play a DVD, but I do have sound when I play a Music CD
Are you sure your player has got the right codecs to play both audio and video of the DVD you have burnt?
PS: Try installing the Ace Mega Codecs Pack just to make sure you have all the codecs. (Remember though that this software will install all the required codecs as well as the unneeded ones...the ones maybe required in the future probably)
Oct 18, 2007 | EPoX EP-8NPA7I Motherboard
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
272 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
