Back to:
Tags:
Jenn-Air JMC7000 Microwave Oven
Turntable no longer turns
posted by rahulbpatel on Dec 06, 2006
Our turntable is no longer turning. If we remove the glass tray the spindle will turn. But with the anything on it, it no longer turns.
Comment by rahulbpatel, posted on Dec 07, 2006
MicrowaveSvc,
Thanks for the very detailed and insightful reply. I'm not sure if this is the same but I can turn the spindle/plastic thing inside the cabinet with my hand and get plenty of resistance. Does this mean its a weak rotor?
I have the JMC7000ADB microwave. I saw the parts diagram. Is replacing the motor a task I could attempt to do myself as a weekend DIYer. Or is this better left to an experienced service/repair person?
Thanks...
Comment by rahulbpatel, posted on Jun 10, 2008
MicrowaveSvc,
Would it be worth trying to replace the motor & coupler myself or do you think it requires an experienced professional to do it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2980 votes
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler.
If the coupler turns loosely without actually engaging the motor, it is bad.
If the coupler is good or looks good, it's probably the motor.
One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad.
You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at
http://services.maytag.com/abs/PartsStor...
You will need to enter your full model, which is apparently one of the following:
JMC7000ADB
JMC7000ADQ
JMC7000ADW
Referring to the CABINET-BASE-CAVITY diagram found there, you will see:
- REF 23 motor
- REF 27 coupler
One of those is likely the culprit.
Comment by MicrowaveSvc, posted on Jun 10, 2008
Sounds like a bad motor.
I would refer you back to my previous answer, where you'll find the link to the detailed diagram.
It's a simple job, really.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Turntable no longer turns:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
the door handle broke off of my built in microwave ...
Microwave Ovens
selecting program but not functioningonn
Microwave Ovens
how do I set power to "medium" or...
Microwave Ovens
Sanyo showerwave inner liner rusting
I know this is a simple fix but, I can't seem to find the...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
