Question about Samsung WF337AA Front Load Washer
Samsung big wash 7.5kg Q1433S fault code 5E
Washing machine does not finish cycle error code 5E always comes up
  • jennyjwat Nov 30, 2008
    this happens on mine too but i cant find my manual
  • Anonymous Dec 03, 2008
    Error code 5E. Water in machine and has not finished the wash.
SOURCE: samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Posted on Feb 15, 2008
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Posted on Feb 08, 2008
  • 43 Answers
SOURCE: fault code 5E
possible pump problem
try cleaning out the filter
Posted on Nov 10, 2008
SOURCE: I have j1045 front load
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Posted on Mar 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Posted on Jun 19, 2009
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Jun 19, 2009 | Samsung Washing Machines
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
441 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
