Question about JVC AV-36230 36" TV
No picture after tv warms up,the screen goes 90% black. if you give it a quick slap on the side, it comes back, but only for a while.
    President:
  • 3,130 Answers
There seems to be an intermittant solder connection inside the set somewhere on the printed circuit board. If you have any soldering or solid state repair experience, open the set while its one, BUT please be carefull, and probe around the high voltage flyback transformer with a wooden tool or rod( a wooded spoon works good). If you have not had any experience with printed circuit boards and or solid state electronics, please call out a pro to assist you as a TV set is no place to be experiementing around inside of. The longer you let this go, the more it will end up costing you. Good Luck PS please do not forget to rate this thread.
Posted on Dec 07, 2006
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Ps-42s5h plasma goes black when warmed up.
we ( technicians ) call it a cold solder or burnt solder , just need to open the tv and give a VISUAL look thru the entire PC Board , good luck , AJ
Nov 05, 2009 | Samsung PS42P2S 42 in. Plasma Television
My Canon Camera's lens will not go back into camera when turned off. It goes in, comes out, beeps and the screen is black. It will let me review pictures taken though.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep theFREE service online ++++ Thank you for using Fixya com
Sep 01, 2009 | Canon PowerShot A75 Digital Camera
Olevia 37 lcdtv has to warm up be repowere for picture to display
It's your power supply. have it taken care of ASAP before damage happens on the board where it can't be repaired, just replaced, "if they can find one".
Jul 15, 2009 | Olevia 237T 37 in. LCD TV
LG Television 37LB4D "Rebooting"
Ours is crapping out just like yours. Picture goes out, "black and white squiggles" appear in the top left of the screen then TV input appears, then it either repeats or gives me my picture back. This happens with both the HDMI slots (tested all 3) and both Component slots. Seems like the bulb or a circuit board on the TV is faulty. What a piece of ****, never spending another dime on LG products. I did get it to come back by hitting the back of the TV with a good slap, but it gets really annoying.
Jun 14, 2009 | Televison & Video
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Screen going black
We have the same problem...I thought you could change the bulb or lamp...but not finding out any info about it! HELP! This TV cost way too much to have problems this quickly.
Jul 27, 2008 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
JVC AV-36230 36" TV Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
