Question about Canon PIXMA MP210 Photo All-In-One Printer
Cannot scan using MP220
I have downloaded drivers for Canon pixma MP220 and although am able to print documents, cannot scan them into my Asus EEE laptop and there is no icon on the desktop
  • ricelaine Nov 18, 2008
    I do not have a cd drive on my laptop so I can only download the drivers I can find on net and so far I have not been able to find the entire suite. would you be able to direct me to the correct place to download? Don't find your help very helpful at this stage - waste of $9.99
    that is the page I have already downloaded the drivers from. I don't think the problem is a scan lock - it's more that I don't seem to be able to access the program to ask it to scan a document. I can print documents with no problem
  • Canon Master
  • 1,879 Answers
Perform a copy to make sure the scanner is working.
Try using the Scanner & Camera Wizard (Start -> Accessories -> Scanner & Camera) (this test is for communication).
If it failed, go to Device Manager (right-click My Computer icon and select Properties, click the Hardware tab and press the Device Manager button). Scroll down and locate Imaging Devices, expand. If it shows, right-click and Uninstall then reboot the computer. If it doesn't, try changing USB port.
Keep in mind that All-In-Ones are two products in one package. The USB port in the printer is like a traffic light directing the signal where to go. Visualize that if the internal link from the printer's USB port to the scanner fails, it is considered a hardware failure.
Posted on Nov 18, 2008
    Genius:
  • 2,035 Answers
First go to start control panel and then scanners and camera ,and check if the scanner is listed then scan from the wizard ,then try to install the drivers through add imagine wizard ,if still cannot install then you must turn off the firewall and antivirus and install the drivers ...and check if it works ..
Good luck....
  • 10,515 Answers
Check the power. Almost everyone has missed this easy fix at least once. Make sure all power switches are on, all cords are plugged in and any indicator lights are showing green. Step2Eliminate the chance for operator error by refreshing your memory on the operating instructions. If you discover that you have been missing a step in the scanning process, highlight the relevant step in the operating manual and try to scan again. Step3Verify the correct positioning of the document you want to scan, which is face down on the scanner bed glass. Spot clean the glass if necessary with a damp cloth. Step4Double-check your scan optimization settings. Some printers allow you to refine their settings for print only, image only or mixed documents. Make sure you have the right one selected. Step5Make sure you have the right computer destination selected in a network. If you are not in a network, examine the cables that connect your all-in-one printer to your computer. Step6Keep the device’s task manager on while scanning. Some all-in-one printers need their task manager in the toolbar to function properly. Step7Pull up the troubleshooting menu for the printer on your computer for more system-specific remedies.
  • Canon Master
  • 541 Answers
    Sergeant:
  • 306 Answers
Click here   for drivers!!
  • 849 Answers
You will find it the link below:-
http://software.canon-europe.com/products/0010486.asp
you dont need to have a laptop cd, it need only printer drivers and application for print and scan.
  • 3,037 Answers
You can download them directly from www.canon.com
Let me know what country you are from and I can find the exact driver for your region, otherwise you can search yourself for it
  • Canon Master
  • 19,396 Answers
You need to download the complete software suite.
  • 4 more comments
  • Ginko
    Ginko Nov 18, 2008
    Some printer has a scan lock that must be switched to open, to prevent damage during transpor, check on the manual if this is the case.
    To scan you need to install the complete software for your printer, installing only the driver wont give you the software tools to manage the scanner.
    Here is the download page for Windows XP.
    Download and install Easy Photo Print and MP Navigator (at the bottom of page) Software
  • Ginko
    Ginko Nov 18, 2008
    I already gave you the link,
    I will repeat my comment, as probably you did not receive my message.
    To
    the scanner.
  • Ginko
    Ginko Nov 18, 2008
    bestdarngood
    Give him my link, I think he cannot read me,
    Another genial Idea from the head office I imagine.
    If you get Fixya I do not complain.
    Better than giving Fixya to some useless poster.
  • Ginko
    Ginko Nov 18, 2008
    After downloading the three files (Driver, Easy Photo Print and MP Navigator) you need to install the three software package , starting installation with USB unplugged.
    You start installing driver,
    Then install the other two packages.
    You need to INSTALL after downloading.
    This if you are using Windows.
    If you have Linux on your EEE, that is a completely different matter.
    Let me know.
  • Ginko
    Ginko Nov 18, 2008
    I do not think it is scan lock either, Pixma MP220 should not have a lock.
    More than accepting the solution, tell me the following:
    Is the EEE working on Windows XP or Linux?
    See also my previous comment here:
    To
    the scanner.
    Did you read it?
  • Ginko
    Ginko Nov 18, 2008
    Remember also that after downloading the software you need to install them.
    I will go offline soon, If I am not online I answer within 24.
Need user manual for Canon Pixma MP220 all in one printer/scanner/copier
Go to the link I gave, Manual Canon MP220, will appear (see image). Look at the bottom, put checks in the "I accept the License Agreement", then click Download (see image).
After the download is complete, right-click MP210_220.zip file, select extract, then open the folder MP210_220 (image 1).
Open the folder manually - Home - Windows (image 2, 3)
There are five manuals that you can read, Contents, Driver, Inst, Photo, and Scan (image 4)
Nov 29, 2011 | Office Equipment & Supplies
HOW CAN I DOWNLOAD THE SOFTWARE OF CANON MP190 TO ALLOW ME SCAN MY DOCUMENTS
Hi, The MP drivers are necessary to print documents and scan images.These drivers must be installed to use the print and scan features.The MP Navigator EX software for windows allows you to scan,save and print photosand documents.You can also edit images or attach images to e-mail using this application software.To download the softwares if you don't have the cd,
1)Go to software.canon-europe.com 2)Under Multifunctionals Select PIXMA MP 190 3)Select your operating system. 4)select your language. 5)Download the drivers and install it
Hope this information is useful to you. Feel free to post your comments. THANKS FOR USING FIXYA......BEST WISHES.....
Dec 09, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Hi. I have a canon pixma mp780. I can use it to print fine with my Macbook pro (OSX), but I cannot get it to scan with either mac's image capture (can preview image but scan button is greyed out) or with...
Hello thanks for asking, i notice you you really did some valid but the problem still exist. Please check the settings for your printer to make sure they are correct, and please uninstall and reinstall the drivers for the printer once again and please make sure its the right drivers for your printer.
Jun 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Hi I lost my installation disc for my mp220 so I can't get any of my drivers like scan programs what do I do
Follow the link below to download the drivers for free.
conan PIXMA MP210 Photo All In one Printer drivers
or copy the link below and paste it in the browser.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402
Select the operating system you're using then you'll be capable of downloading the drivers for free.
Dec 31, 2009 | Canon PIXMA® MP210 Printer
Canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Mar 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP460 problem...cannot scan
i was told that the printer needs to be directly connected to the imac (not airport) for the scanner to work.
i have the same issue w/ the airport extreme.
May 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
75 people viewed this question
old marine
old marine
