Question about HP LaserJet 1010 Printer
Problem with the fuser lamp sleeve
I need a fuser lamp for hp laserjet 1010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Call authorised dealer HP at your region.
Posted on Nov 18, 2008
HP LJ P3015 Printer not printing clearly after replace the sleeve
Reasons:
1. Teflon Sleeve, use better quality sleeve.
2. Apply good quality of Teflon grease.(Don't apply more or less)
3. Chk Fuser temperature..& connectors..
4. Adjust Fuser temperature in fuser mode..
May 23, 2014 | HP Laserjet P3015X Printer
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Hp 1010 Laserjet wrinkles paper
Typically, what causes wrinkled paper is the fuser assembly in the top rear of the printer. This is not a user replaceable part. I would first check to see if there is anything obstucting the paper path like a torn peice of paper or paperclip etc. You can take it to a printer repair shop to get the fuser replaced for around 100-150 dollars.
Aug 27, 2010 | HP LaserJet 1010 Printer
HP LaserJet 1300 Printer: black vertical lines on both side of paper
for this model.. first check if your toner cart is good.. if it's good.. then the cause of your problem is your printer fuser sleeve.. fuser is where the paper is heated up.. and when you start having dirty line print out.. it show that the fuser sleeve(top part of the fuser) is torn..
if you send to HP.. they will probably charge you the whole fuser.. which is expensive.. you can always replace the fuser sleeve only..and it cost not much.. you can always replace it by yourself if you are able to remove the fuser unit..other thing.when you switch on the printer, can you hear sound like paper been crumble at the exit of the printer?
May 23, 2010 | HP LaserJet 1300 Printer
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
Sleeve in fuser unit hp LJ1012 is torn at edge and needs replacement. Technical skills allow me to repair if I have a sleeve.
please you go to a service centre they help you and replace it and install new one ,may be 20 dollar in cost
Nov 18, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1010 paper tearing
If the paper is tearing and creasing at exit the problem is a worn fuser fixing film. This will need to be replaced.
Oct 17, 2009 | HP LaserJet 1010 Printer
Laserjet 1010
where do I download a free driver ofHP LaserJet 1010 Printer
Dec 23, 2007 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
