Question about Hitachi 43FDX01B TV
No main picture, PIP ok
The main picture does not come on, however the sound is ok and the picture in picture works.
  • Ken Phelps Dec 07, 2006
    Thanks.
    Will replacing the caps in the PIP module "fix" the primary "main" picture? The PIP seems to be working fine.
    President:
  • 3,130 Answers
There is a repair kit, for the PIP module, as thats where your problem lies. if you know how to solder on and off surface mounted capacitors, its a breeze to do, but if you dont, you will most likly put to much heat on the board and the landings and printed circuit traces will come up, so if you decide to do this yourselfs, please be carefull. The kit is available at this link.http://www.mcminone.com/search.asp?keyword=Hitachi+PIP&btnSubmit.x=10&btnSubmit.y=8 If you do not feel comfortable do this, maybe you know someone whos an electronic hobbiest and can replace these for you .. Good Luck PS please do not forget to rate this thread.
Posted on Dec 07, 2006
  • Larry  Dillon
    Larry Dillon Dec 08, 2006
    Yes the main picture runs through the PIP module my freind.
No picture on main screen
Sets with PIP use two tuners--one for main and one for PIP---likely the main got hit with the static discharge during the storm----Here we always disconnect both power and cable when a storm.
There is a way around this (will lose PIP) with a cable box connected to the audio and video inputs on rear of set---bypass the tuners and use the box to change channels and provide signal.
let me know if questions.
Nov 07, 2012 | Televison & Video
How to work pip in vizio tv
PIP or picture in picture works in two ways with the original remote--new sets with this actually have two tuners in them, one for main picture and one for PIP picture, you can change channels in both, swap the PIP to the main picture or even have both side by side.
Sure its got the PIP? what is brand and model number ?
Oct 30, 2012 | Televison & Video
My picture in picture isn't working?
Most of these sets have two tuners--one for main and one for PIP.
If main picture works fine but PIP is bad or Green? either the PIP tuner or the PIP board is bad---these were known to have the PIP have problems but it was more rare than their sets made before it.
SD TECH
Apr 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Ilo problem
What I hear you saying is that your main television tuner shows lines only while the PIP is functioning properly. The PIP works by using a separate tuner from the main tuner of your television (like a vcr tuner). Since the PIP works then it appears that your main tv tuner is not working anymore. It will probably have to be replaced. I recommend looking at our online technician list for a professional near you.
Good luck :)
Jun 20, 2008 | iLO 3200 32 in. LCD Television
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
No picture, sound OK...setup menu shows up, able to get picture in PIP
You will need to check the inputs on the television. You more than likely have a bad video in signal. This can be a bad cable or a loose connection either at the input of your television or at the output from your receiver, (cable or satellite). First, try wiggling the cable and then try replacing it. This should fix the problem. If not, your signal may be routed through a stereo or other switching device?
Apr 17, 2007 | Samsung PCL541R 54" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Hitachi 43FDX01B TV Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
