Question about Gateway Wireless Connected DVD Player
Connection of speakers
How to conncet many speakers to my dvd player with suitable amplifier for my 5.1 channel player
  • 38 Answers
You must be aware of the output impedance of your amp
you connect speakers in parallel and series in combination. eg- if the output impedance is 4 ohms,
connect two 8 ohm speakers in parallel
0r four 4ohm speakers as follows :- two pairs of speakers in paralell [+to+, -to-] then connect the +of one set to the - of the second set and the other two wires to the output.
Posted on Nov 18, 2008
ADCOM7500 how to use it?
Good gift. It is a 5 channel power amplifier and I do not recommend to connect any sources directly to it. Now you need to buy a preamplifier/ receiver from Adcom GTP series or other brand to connect you dvd player, cd player, cable box, playstation etc. you need 5 good speakers to get your surround sound (or 2 for stereo)
Dec 28, 2011 | Adcom GFA-7500 5-Channel Amplifier
I have an old Philips Amplifier which I bought 18 years ago. The Amp actually can handle 5 speakers but I only connect 2 speakers (L & R). When I play certain DVD, although the background music sounds...
If you identified the specific products involved we (and you) might be able to look at the documentation and verify the obvious answer. Voice is generally concentrated on the center channel, so, yes, a speaker there would be a good idea.
If you don't have a multi-channel rig you shouldn't feed multichannel audio to it. Maybe use the unidentified DVD player's analog output and make sure it's set to mix the channels down to stereo.
Jul 01, 2011 | Philips Audio Players & Recorders
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
Require speakers of sony make model no.DVPNS67P
The Sony DVP-N67P is a standalone DVD player which was produced solely for the Indian market with two analogue left and right audio outputs (phono sockets) and coaxial and optical digital outputs.
You cannot fit speakers directly to this unit, instead you must fit an amplifier with suitable matching input sockets and a connecting lead and then fit whatever speakers suit the amplifier. The amplifier and speakers can be of any brand, they do not have to be Sony.
Nov 06, 2009 | Sony Televison & Video
My center and surrond sound speakers don't work with just one output from my dvd do I need to purchase an amplifier also?
You need to first check whether your dvd player supports dolby 5.1. If it supports that then you could connect the digital output of your dvd player to a surround receiver such as Yamaha RX-661. You can then connect all the speakers to the output of RX-661 which has 7 inbuilt amplifiers for all the channels. Its a 7 channel receiver and would be useful with DVD-Audio and such that comes in 7 channels. For your requirement any 5 channel receiver will do. Please let me know if you need any more clarifications.
Jul 28, 2009 | Audio Players & Recorders
I CAN NOT GET ALL 5 SPEAKERS TO WORK
I know this is not the answer that you want to hear, but: That television is not capable of delivering audio output to all 5 speakers - it is a stereo-only TV, which only delivers 2 channels.
Furthermore, that Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | Coby DVD-937 5.1 Channel DVD...
Question: how do you connect to a cable box?
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Gateway Wireless Connected DVD Player Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
