Question about Daewoo DTQ-26S1FC 25" TV
Daewood tv model # dtq-26s1fc
Sound starts out fine but after awhile it stops. the picture is fine but the sound is gone. sometimes it will come and go while watching it.
You are having a intermittent sound problem probably some lose solder or in the audio circuit.take the set to a tech to have it repair.good luck.
Posted on Mar 30, 2007
  • arnoldtvshop Apr 05, 2011
    Check C810 (1000mfd 25V) in the sound amplifier's power supply.
C804 transister burn and i cant see the parts number so i am asking you if you could help me
To which section of circuit this transistor fitted. Horizontal output section? Power regulator section?
May 28, 2012 | Daewoo DTQ-26S1FC 25" TV
I would like to know the transister number for q804 section of the tv board
Download the service manual to your set. It will have all details. Click here to download it.
I found the code for this and programmed it with the Comcast remote. I can press power and the tv (daewood DTQ-20N2FC model) will come on and off. If I press cable or tv, those lights flash. But I can't...
Heres where you need to go for the codes and programming procedures;
http://www.comcast.com/corporate/customers/customer_support/remotes.html
May 01, 2010 | Daewoo DTQ-20N2FC TV
No power
unplug the unit for 24 hours and try it again. if the unit doesnt come on at all, even after that, then the internal fuse is blown, or a power spike / surge has friend part of the internal power supply. you'll have the go through the warranty process of the manufacturer, or find a local tv repair shop.
Sep 24, 2009 | Daewoo DTQ-27S5FC 27" TV
Que regulador maneja el tv dtq- 26s1fc
Senor....You have 2 bad capacitors on the deflection board..They are 160 volts 1 mf and you may have to check the the large Horizontal cap , I think it is 25 volt or 35 volt 1000mf cap. Good Luck PS Look for 250volt 4.7 cap is bad too! DE NADA!
Sep 24, 2009 | Daewoo DTQ-26S1FC 25" TV
NO PICTURE
there is a broken conductor strip or broken solder joint on the circuit board near the power input jack. do this: 1.) disconnect tv and open panel to expose circuit board. 2.) using a flashlight and magnifying glass, look carefully for this broken solder strip or solder joint. Flex board slightly if necessary to aid in finding the break. 3.) repair it using solder iron and flux solder and scratch copper conductor slightly to aid in "wetting" the solder fix.
Jun 09, 2007 | Daewoo DTQ-26S1FC 25" TV
TV shuts off
there are some capacitors in the power area that need to be replaced. open the set and do some checking there and I am sure you will find the problem. good luck
Sep 04, 2006 | Daewoo DTQ-26S1FC 25" TV
Daewoo DTQ-26S1FC 25" TV Logo
233 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
