Question about GE ® 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG
GE Washer intermittently stops 1/2 thru cycle
I have a GE Washer model#WTRE6260 about 2 1/2 years old. When using the About 75% of the time it will just stop at times during the cycle and not finish. It usually stops at the end of the wash cycle but ocassionally it will stop during the rinse cycle with the tub full of water. I'm thinking the electronics are messed up. I tried unplugging from power for several minutes like the book says but didn't help. (left it unplugged for a couple of hours once) Is there any way to tell for sure short of calling the service guy? Any other advice on how to fix or troubleshoot?
Thanks
Duaine
4 Suggested Answers
  • 35 Answers
SOURCE: my 2 year old front
I'd suggest checking out some other posts regarding that model, here on fixya. Perhaps reviewing those will help troubleshoot/isolate the issue.
http://www.fixya.com/search/p479454-ge_energy_star_wcvh6260f_front_load/wcvh6260
Cheers.
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
Posted on Oct 14, 2008
Daniel S
  • 4323 Answers
SOURCE: ge profile wpre6150k1wt washer does not complete
Hi
First make sure to test the lid switch assembly, you can jump it to test it. If the lid switch and motor is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Oct 02, 2011
I have a GE front load washer model number WBVH5200J1WW that’s 7 yrs old. During the wash cycle it will pause. Have to reset & it does this all thru wash cycle
If this is only on normal wash and not happening on the other cycles then you have a problem with your timer program for the wash cycle. try spinning the dial all the way around simi fast. Stop on off before wash cycle and try it.
No error cods? let me know
Mike
Dec 12, 2017 | GE Washing Machines
I have a GE washer machine model #wwa58500r (about 18 years old) that is leaking oil or oil fealing item, under the washer. What is it, how important is it to fix it (since it is so old) and how can I...
The lower seal is leaking. Over time the seal hardens and does not perform as it once did. Although this link is not your exact model the transmission is exactly the same. The seal that is leaking is item 756.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230798&diagram_id=20372026#d20372026
Close up view of seal
http://www.appliancepartspros.com/part_details.aspx?part_id=2045443
It is not a difficult task to change the seal. The hardes part is getting the old seal out that involves punching thru the old seal and prying it out after removing the drive pulley. Use a block of wood to gently tap the new seal in place.
Thanks for choosing FixYa.
Kelly
Sep 07, 2010 | GE Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Jan 07, 2009 | GE WDSR2080D Top Load Washer
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Oct 14, 2008 | GE WBSE2090A Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
GE ® 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG Logo
54 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
