Question about Rockford Fosgate Punch P163C 3-Way Speaker - 7" Coaxial ¿ Polypropylene Cone ¿ Titanium Composite Do... Car Speaker
Speaker Distortion Hi, I have replaced my front speakers with Rockford Fosgate p163c 6 1/2". When the volume is turned up, they distort quite a bit. Was expecting better sound quality from these speakers. Someone mentioned that it could be due to the headunit not being powerful enough. I have a factory cassette player headunit, which probably puts out low wattage. If I replace the headunit (to maybe one with 50 x 4 watts) would this improve the sound and possibly stop distortion at higher volumes? Thanks
  • 67 Answers
YOU WOULD DEFINITELY NEED MORE POWER FOR DOES SPEAKERS . WHAT YPU SHOULD UNDERSTAND IS ONCE YOU HAVE AN AMP. THAT RATES HIGHER THAN YOUR SPEAKERS U WOULD ALWAYS HAVE GOOD SOUND RESULTS BECAUSE U DONT HAVE TO MAX OUT YOUR AMP VOLUME .
Posted on Nov 20, 2008
    Problem Solver:
  • 8 Answers
Upgrade...... definitly a wattage problem... most units today will have rc outputs i would suggest spending the extra 50 and get a unit with dual rca's and invest in a small 100 watt amp to run your highs this will prevent any future distortion as well as prevent you from putting undue load on your stereo; hince longer performance and clarity from your head unit
Posted on Nov 19, 2008
    Problem Solver:
  • 4 Answers
I would definitely say yes to the new HU, however at the same, the issue could be the actual wiring from the deck to the speakers. If you've got a cassette player in there I'm assuming the vehicle is a bit older. Over time the copper in the wiring has a tendency to corrode if exposed to the weather. Either way replacing the player is a win-win situation since you'd be stepping into the CD era (lol), but if it doesn't make a difference I would be looking towards the wiring. Outside of that the only possible wild card would be you bought faulty speakers, the odds of that being very low since it's coming from both. Hope this helps.
For a 12 inch 4 Ohm DVC with 1200 Watts Max/400 Watts Nominal what size amp should I be using?
The speaker info is telling you that a 400watt input is nominal or stable. and handle anything that can Peak up to 1200watt , the speaker can handle the 1200watt but not for long periods. Distortion will likely occur well before then anyway. On my home stereo, I have twin Marshalls which are 500 watt each going to JBL,s rated at 150 watt with 250 peak. The ratings are a bit different from manufacturer to manufacturer. Ive found the system is really powerful but there is very little to no distortion as the amp is not needed to be cranked up to get the volume I want. If you run an amp that is too big for the speakers, it will sound really loud for a while, then distortion happens then watch your speaker cones self destruct or the voice coils burn out. If you run an amp that is too small, you will need to turn it up more for the volume and then distortion sets in earlier, which is the biggest destroyer of any speaker.
May 26, 2015 | Car Audio & Video
I have 2 15"L3 kickers and I'm running them with a Rockford Fosgate T1500-1bdCP what should how do I tune my amp and speakers
turn down the gain until you can go full volume without distortion.
crossover frequency is always up to the user.
Feb 07, 2015 | Rockford Fosgate Car Audio & Video
My surround sound sony 7.2 ampli audio turns off when i turn it up
try checking if all the speaker cables are connected in polarity ( all + to + and all - to -
make sure that the speakers u have connected are not below the amplifier manufacturer specs and that that they all have the same OHM load (check back of speakers to see the (OHMs)
lastly, check each speaker individually to determine that they are all working and working with no distortion. ( a malfunctioning speaker could cause the amp to go into protection.
if there are any more details that you did not state please do so.
wish this helps
......andy......
Jan 02, 2014 | Rockford Fosgate Punch 601S Car Audio...
Rockford Fosgate Power 1000 amplifier. (25 to life) When I turn it on there is almost no sound coming from speakers. I have to turn up the volume almost to max to hear something. But only very high...
turn or flip the LPF and sub sonic buttons to see if they will help.
there are other buttons called gain that you may have to turn to bring up the volume.
its very likely your eq buttons that you have to mess with to get it right. post up pics if you can.
Nov 02, 2013 | Rockford Fosgate Car Audio & Video
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
I am very inexperienced with any audio systems. I have a rockford fosgate P312 D4 12'' sub connected to a kenwood KAC 9102D amp with a 1 Farad capacitor. I was listening to it at about 60% with a song that...
there should be a small sesistor soldered onto where the wires are, if so, then this has blown, in some cases,you can remove this, but you will lose any overload protection that it was originaly put there for
Aug 03, 2009 | Rockford Fosgate Punch Stage P312 D4 Car...
GK 1001 rb speaker overload, is my guess
This problem is not likely to be a volume control problem. There is a transistor inside that is failing (getting noisy) when heated up. If you have no experience with amp repairs, do not attempt this as it is not simple to locate the defective part. Continued use in this condition can cause problems with the speakers. Please have this serviced by a repair shop with experience with GK gear.
Dan
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
James
Do you have the amp bridged first off? if you do unbridge it. Next,
1) Turn all the settings all the way down on the amp.
2) Turn your bass on the radio into the negatives (-2 or-3)
3) Turn the volume up to the point where your highs start to not sound good, then turn them down just enough to where they sound good again.
4) Turn your crossover to about half if your box is ported, or three Fiths if its sealed.
5) Raise your gain slowly untill either the volume doesn't get any higher or you hear the subs start to sound funny. Now turn it down just a hair.
6) Turn your crossover up a hair then down a hair and see what happens, if it gets a touch louder with out distortion then leave it. If it losses clarity then place it back to where it was.
7) Listen to a couple songs you know well and stand in front of your subs at volume to be sure theres no distortion.
You should be good at this point let me know if you need something else.
Dec 02, 2007 | Rockford Fosgate Punch P2002 Car Audio...
Car Audio & Video Logo
172 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
