Question about Haier Dishwashers
Slight water leak towards end of cycle
My dishwasher is about 18 months old and all of a sudden I get a small pool of wateron the floor.
Watching as the dishwasher was running the water comes from behind the stainless front part of the door at either corner.
The blower fan has also just started to make a noise like it has movement and is catching
Haier HDW201SS
    Scholar:
  • 93 Answers
Did u notice the Quantity of detergent used? If the leaking water is soaping, it is an indication of excess detergent used that cause the leaks. Reduce the detergent n observed the DW running, or run the DW without detergent several times to remove all residual residing inside the washer.If not check the door gasket or change the door gasket.
Posted on Nov 19, 2008
LG dishwasher model LDS4821- 16 months old- getting E1 error. Water leaking on floor. This happened before 3 months ago but then had no other problems with it until now. No other problems with this machine...
Hi ferrojennife,
The E1 you are seeing means Water Level in Drum lowering, this means there is a leak on one of the pipes. More likely it is the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
Jun 09, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
My Kenmore (Mod # 665.17842400) dishwasher stopped towards the end of a rinse cycle (dishes were almost clean). A pool of water is in the bottom now and the controls don't come on anymore. I just...
You may have a small leak in drain hose. check the hose when the unit is draining, you may see the leak.
Let us know if you need further clarification.
Thanks for contacting fixya.com
Dec 03, 2009 | Kenmore Elite 45986 Front Load Washer
Water leaking on floor. wateron top of crisper
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Make a clip at the other end of the wire , and " clip " it over the glass tube (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 29, 2009 | GE (GTS16BCS) Top Freezer Refrigerator
Draining water on kitchen floor
I am not familiar with your model dishwasher, but had a similar problem a few years back. I am assuming you have checked the obvious causes, such as a worn, or damaged gasket around the door. My problem was fixed by replacing the lower spray arm. The spray arm is a couple inches wide, about 18 inches long, has holes in it and rotates as it dispenses water - some lift up during the wsk and rinse cycles. In my case some of the holes got plugged up with gunk, which resulted in the water shooting out harder and further from the other holes. Those streams of water went places they were not designed to go and ended up on my kitchen floor. So check that part out and see if it is the cause of your problem. Good luck!
Mar 21, 2009 | Kenmore 46462 Front Load Washer
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
207 people viewed this question
Top Haier Dishwashers Experts
Renee Knafel-Bullock
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
