There is a double line appearing on photocopies and some faxes. The ink cartridge has been changed but still having the problem.
    Master:
  • 569 Answers
Try cleaning the rode
Posted on Nov 18, 2008
I cannot photocopy with Epson Stylus CX390
I would say that one or more of the ink cartridges are running low on ink. Have you tried changing the ink cartridges?
Aug 14, 2014 | Epson Stylus Office Equipment & Supplies
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer does not print good copy after doing several head cleaning operations and having enough ink in cartridges.
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
Feb 20, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
Black ink not working on Brother Intellifax 1860C
All i needed to do, after messing with it non stop, was turn it off and reboot the machine. Simple solution! Thank god!
Apr 28, 2009 | Brother IntelliFax-1860C Plain Paper...
Wrong cartridge message pops up and won't print because of it
Even with new cartridges sometimes the pc board that is attached to the cartridge can get dammage,replace the faulty cartridge.
Jan 07, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Change the ink carridge it says alins cartriges.cannot photocopy.
Make sure you have replaced BOTH of the ink cartridges. Then it should align.
Sep 04, 2008 | HP Office Equipment & Supplies
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
