Liquid Video LIDM-830 portable DVD player need parts
Where to buy service parts; ''video display ribbon cable''.
Cannot find service support or parts dealer!
Lost or broken display image, due to failed video display ''ribbon cable''. Routing video display cable through screen hinge caused micro mini ribbon cable to fracture at area of case hinge. Ribbon cable connects from lower player main frame to upper display screen ''lid''.
Have three identical units all with same problem!
I believe Circuit City originally distributed this item however they are little to no help and do nothing for cutomer service support.
fairlane
  • 50 Answers
SOURCE: Definite ribbon problem!!! Need help.
Hi It's sad when a simple problem, causes a piece of equipment to be thrown away, while all the expensive parts are still ok. If you are mechanical, and can carefully take the unit apart,(make sure it is unplugged), the ribbon cable may be a plug-in type, and you can remove it from it's connector on the monitor end, and in the main unit, and if you bring it to your local electronics repair shop, they may give you one if they have one the same size (same # of conductors), or sell you one for a few dollars. Otherwise, if you have a fine tipped soldering iron, and experience soldering, you can bypass some or all of the damaged connectors in the ribbon cable with small wires. Cut them to length, and solder them to the respective pins on the ribbon cable connectors. Hopefully, you can see which lines on the ribbon cable have been damaged, and will only have to hard-wire bypass a couple. Otherwise, it would be more economical to replace it. Hope this helps! Good Luck!
Posted on Nov 30, 2006
  • 979 Answers
SOURCE: 7" LCD Video screen Ribbon Cable - need replacement - can anyone help?
You may be able to find a comparable cable on some other brand, but Cyberhome seems to be defunct. An alternative is to find another unit of the same make and brand and scavenge what you need...accordianman
Posted on Jan 25, 2008
SOURCE: need to change flat ribbon cable
this cable  in http://www.slawmir.com.pl/
Posted on Apr 18, 2009
ColdTattoo
  • 219 Answers
SOURCE: I need a car adapter for an 8
Radioshack makes car adapters for just about anything; they're called IGO adapters. Take your item in and they will match the tip and give you the adapter. It will run about $30 but it's well worth it.
Please give me a good rating if this helped! Thanks!
Posted on Dec 01, 2009
SOURCE: RCA DRC630N portable dvd player - blank screen, controls don't work (but powers up)
my "RCA DRC627N PORTABLE DVD PLAYER" has been asking me a activation code . therefore it cannot play any disc, but it can play USB mode. so please help me to get activation code.
Posted on Jun 07, 2011
My ribbon is broken and need a new one to replace it, where and how to get one is my problem
You can buy one parts portable dvd from ebay to use the replacement part. Ribbon cable can be soldered together if you try that first.
Oct 22, 2010 | Panasonic DVD-LS90 Portable DVD Player
The unit displays only a random bunch of horizontal lines. It used to do this after playing nicely for about 10 minutes or so, but now it starts off with a screen full of lines, as though it's reading...
Yes this can be a problem with the player itself most likely with the screen part of the player that may need to be repair,, if its still under warranty you can contact the manufacturer for repair or for replacement....
Good luck......
Aug 19, 2008 | Televison & Video
I need a car adapter for an 8" portable Liquid Video DVD player Model #LIDM-830
Dec 01, 2009 | Computers & Internet
Screen won't show anything
You need to test the video output circuits with the help of the supplied cables and your television. Hook up the audio video cable supplied with the dvd player from the dvd player output circuit to the television input circuit.This set up is explained with a diagram on page 17 of the owners manual.After completing the connections, place a dvd in the player and play it. If you can see the video and hear the audio, then your video and audio circuits are still working correctly. You may just want to use this set up for the dvd player instead of attempting the repair process.The problem will be with the connections between the main board and the lcd display. This problem may be a bad connection or dirty contacts in the connection.You can take apart the dvd player and clean the connections.There is a chance that a connector is damaged and will have to be replaced.These connectors are usually ribbon cables and should not be that expensive to replace.The connector will have a part number on it. This is the number you need to look for a repalcement part.When you take apart the dvd player you should completely clean and remove all the dust and debris from the inside of the player. This can be done with small brushes and a can of compressed air. If you cannot see the playback then you are having a problem with the video output circuits. This problem will have to be repaired in a service center. The repair may not be worth it as the cost may be as expensive as a new player..The telephone number for Zenith customer support is 1-800-243-4994. They will be able to tell you how you can get service and repalcement parts for your dvd player. I hope this information helps you with your problem.
Apr 12, 2009 | Zenith DVP615 Portable DVD Player
Volume wont change
unfortunately these units require the remote to adjust volume visit www.remotes.com they have the remote for mvohd70 (the infrared headphones have volume on sides) if it is RCA cabled to your head unit you can control sound in car but if you are referring to the direct headphone jack remote is the only solution
Feb 15, 2009 | Liquid Video MVOHD70 Car DVD Player
Has anyone successfully connected an external device to the video inputs?
First, the R/Y/W connections are "composite" not "component" video. Component connections are green/blue/red and are a superior connection basically on the same level of quality as HDMI. If you have your TV and VCR connected this way, it will not be compatible with the RCA Y/R/W. I think you are confused as to what component and composite connections are. And, why would you want to connect a DVD player to anything at all other than your TV or a DVD burner? I don't get it.
If you are using R/W/Y, that is basic and the least sophisticated connection available. Further, if you connected this unit to your TV, then you would want to set its connections on "out", not "in", then plug them into your TV.
Mar 10, 2017 | Liquid Video MVBG619 Portable DVD Player
Liquid Video MVBG619 Car power Cord
Hi Lauri3 just wondering if you would have just 1 of the remote control units for this dvd player for sale. Please let me know.
Thanks
veryounique@hotmail.com
Aug 06, 2008 | Liquid Video MVBG619 Portable DVD Player
Jan 04, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
