is REVERSE OK
is PRNDL ( is L okay)???
OK what is the correct order to test. for sure not that
the service manual covers that, for sure the TCM.
1: ;all fuses good ,every one.
2: next is scan the PCM why skip such a key step> here??????
what if speed sensors fail.?
what if load modulater fail in the box.
the transmission book there and ATSG books tell you that and tells you that pump pressure test ports must be at spec or upshifts fail.
if pressure is low (or vast reasons) it can not fully operater the 2nd gear Servo piston to do so,
see my crude drawing her. (older tech box but works same in principle.
do you know what Limphome means for engine and trans?
on the trans, the TCM brain see horrible errors ,(you ignore)
and goes to limphome mode on the box. just 1 year or 2,
depends on actual box model like 4L60? GM box.there?
not sure I will look it up. not saying I know all Limp modes on all boxes.
below the shift lever is now a bank of shift solenoids
but they do the same thing.
if pump and its regulator work and filter not packed up or sucking air
the pump will have spec pressure at idle and the stall load test
the speed sensors must all work and no P07xx errors allowed
even some engine fail can set the trans to limphome too.
the FSM covers that (factory service manual)
ahhhhh you have this transmission same as my wifes GC2010
4 Door; 5-Speed Auto W5A580 Trans. aka NAG1, and 722.6
I have full manual books on it. but not your TCM
or it has this box
42RLE
learn to decode your VIN and see what trans is there first.
and scan it. next after fuses.
The scans see it all, engine and trans both.
and must never be ignored.
as soon as they have to change the filter, oil, the kit of transmission, it is become normal. tkanks for answer
