Question about Kogi l4bx-na ko 14.1" Flat Panel LCD Monitor
Dell flat panel monitor
I have a dell 19" The monitor when I turn it on looks like its about to turn on (although the screen doesn't show a picture) and then the green power light keeps going from green to no color and green and no color almost like its flickering I know its not the video card because I tried it without hooking it up to the computer. I also have another 19" which works fine and I used the same power supply/cables. Is it stuck in safe mode or can I take the monitor appart and tweak something. Let me know. Anyhow who can truely help really knows there stuff.
  • 9,098 Answers
It's a problem in the power supply section inside the monitor. It needs component-level electronic troubleshoting.
Posted on Jan 21, 2007
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have a dell inspiron laptop, and a dell monitor hooked up to it, i turn on the monitor and it is very bright for about half a second then it becomes very dark, so dark that it looks like it turned off,...
Does the fault appear on the laptop screen aswell? It appears by your description that the fault is only on the external monitor. If the screen comes on for a moment and then goes blank as described, then this appears to be an invertor fault. It is very common among laptop and tft screens and requires the invertor inside the panel to be replaced / repaired. Simply plug the screen into another computer to confirm.
May 29, 2011 | Rosewill R900J 19" Flat Panel LCD Monitor
My Dell? E198WFP Flat Panel Monitor the gree ligth on the power botton not working
green light on means your monitor showing display.change your button .your monitor working properly.
Jan 15, 2010 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
Nov 05, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Kogi l4bx-na ko 14.1" Flat Panel LCD Monitor Logo
107 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
