Question about Zanussi WJS1265W Front Load Washer/Dryer
SKIP/RESET BUTTON NOT WORKING
I have Zanussi jetsystem turbo 1200 WJS 1265W.I put the clothes for drying for 10 minuits and the 10 minuites doesn't change at all even though the machine is drying. But now ,I cannot stop the drying by pause and skip/reset.
  • marineman Nov 19, 2008
    Exactly the same problem.
    Still trying to repair it.
  • 67 Answers
Hi
 the i like abhishek answer
Posted on Jan 05, 2009
  • 26 Answers
Many possible problems here.
Have you seen an error code such as E90? Usual problem with this fault is the interboard harness.
This is a small wiring loom between the user interface board and the control PCB.
UNPLUG appliance and remove lid. You will see a wiring harness going through the metal fascia of the appliance,usually blue in colour, and with about six wires. Trace the loom back to the main PCB, located on ther front left of the appliance. Remove the connector block and CAREFULLY bend the metal tabs out inside the connector block. Do the same on the user interface board by first removinh the plastic fascia.
That should cure the problem when reassembled.
If not leave another message and I will tell you how to access the onboard diagnostics
Posted on Nov 19, 2008
Abhishek33 Thanks for trying but this model is all electronic, no mechanical timers etc.
HOWEVER,
Left the machine on , (drying, as it could not be cancelled) overnight (not cheap) in Morning clothes very dry, door was unlocked and now washes ok. Dare I try the dryer again!
  • manmarine Jan 05, 2009
    Instant cure and relatively easy. Had no problems since repair.
    The terminals and connector block looked perfect when removed but a clean up cured the problem,
    Cheers Micmacmac
    Genius:
  • 1,239 Answers
Hi
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
I replaced the battery and the sirius radio doesn't work - it is stuck on aquiring signal for over 30 minuites. The owners manual says to wait at least 10 minuites and it should resync but it...
Disconnect the negative battery cable for 10 mins, then reconnect it and try. Sometimes it can lock out the Sirius unit, and by disconnecting the negative battery cable for 10 mins, clears out the whole system so it can be booted properly.
Thanks Jay!
Jun 26, 2011 | 2007 Nissan Murano SE
Minuite hand moves evey 10 seconds
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio G-Shock Tough Solar Frogman Divers...
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Change door seal on wjs 1265w
Hi, Your new door seal will have a double lip seal? If you use a small amount of washing up liquid on the lip of the double seal this will then allow you to ease the door seal on really easy. The spring then goes on the outer part of the seal in the groove to hold it onto the tub. Becareful and make sure you put the door seal on the right way up or you will not be happy with the result! TORN CLOTHES!
Good luck...
Dec 05, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
376 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
