Sennheiser RS120 cuts out after three minutes of silence
I have a pair of wireless head phones that work great for my computer. The problem is when i'm not making any sounds with the computer for about three minutes, the on/off light goes out and makes the headphones give a loud static sound. I'll have to click on something if i want to get the static to stop.As far as i can guess, it's a bad feature they have to cut the power when they aren't being used. I'm wondering if there's anything i can do to fix this problem even if i have to open it up and solder all the way to making some program that makes a click sound every three minutes because the burst of static is really bad.
  • rufino1 Jan 23, 2009
    I have the same problem and I'm a bit frustrated.
    Have you found something to improve it.
    Regards,
    Rufino
    chondeville@hotmail.com
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
  • 155 Answers
SOURCE: My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
Posted on Apr 30, 2009
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
  • 155 Answers
SOURCE: Sennheiser RS120 with noise...
Couple of things could be going on..
Try the obvious first
1. Select a different channel on the base unit: Located on the front, under the logo is a small switch. Note the position and try the other two settings
2. Make sure your base unit is not next to other items that may interfere with it.. cordless phones and wireless network routers etc.. microwaves or other RF sources .. fluorescent lamps.. etc
Lastly.. just about all wireless headphones have some noise or background hiss.. but it should be minor.. if the rechargeable batteries are not taking a full charge or cannot retain the charge properly.. the reception will also weaken.. and that noise will increase.. and the reception distance will decrease.
You can buy a new set of rechargeable batteries .. just make sure they are exactly like those in your headphones..
If I remember right.. they are Nickel Metal Hydride… (NiMH).. Radio Shack will have them.. or a store like Batteries Plus.. If you replace them.. go for a slightly beefier battery.. a higher mA-h.. may take a bit longer to charge initially.. (If you try this.. remember.. they will need to charge overnight before use) but will “play” longer in use.
It has been noted that many of these headphones shipped with inferior batteries.. that problems seems to have been addressed by the mfg.
Good Luck!
Posted on Jul 07, 2009
  • 155 Answers
SOURCE: My Sennheiser RS 110 headphones won't work. I
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Posted on Feb 12, 2011
Should I hook it up to my cable box or tv?
Hook it to the TV. That way if you play a dvd you'll hear it. Cell phones will interfere, as well as cordless phones, so there's not much to do about that.
Nov 17, 2014 | Sennheiser RS120 Wireless Headset
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser rs120
Problem solved - had to remove ear pad to reveal screws underneath.
Jan 21, 2014 | Radio Communications
I just purchased another RS120 to put in bedroom, have one in liveing room, the one in the liveing room works great but the one in the bedroom will not work, it will pick up the show from the liveing room...
is there a frequency channel selector on the headphone base, and on the headphones? the two pairs must be on different frequencies, or they will pick up the same show as the other
Oct 21, 2013 | Sennheiser RS 120 Consumer Headphones
Sennheister RS120 head phone left ear no sound
Dear friend ,
try to check wiring connection by opening tic tac locks of left side. If there is loose connection solder it .
Sep 30, 2013 | Sennheiser In-The-Ear PC Headset Headset
I have lost my manual how do I pair my earpiece?
If you go to the following webaite:
http://www.sennheiser.com/comm/icm_eng.nsf/root/products_mobile_vmx100
Under the Download heading you will find a link for the Consumer Brochure. That is the user guide that you need to download for the steps to take to pair your headset and phone.
May 21, 2010 | Sennheiser VMX100 Bluetooth Headset...
RS110 one earphone not working
It could be the input source.Try it on another device.
Sep 16, 2009 | Sennheiser RS120 Wireless Headset
126 people viewed this question
 Grubhead
Grubhead
