Question about HP Office Equipment & Supplies
Paper jams in my hp deskjet f4180 - HP Office Equipment & Supplies
    Novelist:
  • 180 Answers
At the back of the printer there what we call as rear access door. open that door and you could see the rollers. clean the rollers with either a lint free cloth or a cotton swab/ball/strip and moist it with water. if that does not help the paper sensor and printer mechanism is damaged. nic61 is right do not let your printer be service by firms. it will cost you alot. and by the look of this printer model this probably is in warranty. you can call hp and asked them for a replacement. it will be a remanufactured product. even you will be escalating this to their case managers' they will just lie to you that they are going to send new a printer. The printer may look brand new but it is already used. its up to you, if you are in warranty and wants a working printer call them.
Posted on Nov 19, 2008
    President:
  • 1,073 Answers
Hi!
You need to clean the 2 big black weels where the paper passing through inside your printer.
If that dosent help, buy a new printer. Its cheaper then leting some firm fixing your problem.
Deskjet f2180 crunching sound when switced as though gears on wheels not lining up it was working fine then was printing photograph then made that noise and stopped had to free paper from the rear also cartridges do not move to centre when cover is flipped down any help appreciated
Posted on Jul 18, 2009
I had a paper jam and when I pulled out the paper, the printer began blinking. I shut it off and now it will not turn on again. HP Deskjet F4180
Hi
Please check that a small piece of paper is not stuck in the printer. Hope this helps...please post back for further assistance.
Daniel
Feb 19, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Hp F4180 continually gets false paper jams wihch kill the current print job. Is there a way to get the software to ignore paper jams reported by the printer or simply disable the paper jam sensor?
have ever serviced the printer? if no please get it an expert for servicing,
you may read thru this to guide you
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566
Apr 30, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
My HP F4180 printer jams with 220gsm card
The HP F4180 is only rated to 200gsm for card. You can do slightly thicker 236gsm for photo paper.
Mar 07, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
My hp deskjet all-in-one f4180 worked just fine until one day the paper started feeding in crooked every time Thanks in advance
Sounds like an old paper jam, were there is still a "small piece of paper in the takeup rollers. Check with a torch, just to make sure takeup is clear.
Nov 13, 2009 | HP Color LaserJet 2600n Printer
HP Deskjet F4185 series says a paper jam error everytime I print using a photo or matte paper.Everything is clean though so I don't know what to do with this error.
did your orinter experience a paper jam before?
try to clean inside again maybe there are small paper left inside
i hope this can help
Oct 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How to change ink cartridges? Release jammed paper? Paper won't feed!
Sounds like it needs cleaning:
You will need : 1 can of "compressed air", 1 container of ether rubbing alcohol or some form of Goo-Gone.
1. In short blasts (NOT LONG ONES) blow through the paper path. Open any paper jam access trays before doing this so the bits escape.
2. Using a SMALL amount of Goo-Gone and either a Q-Tip or small dust free cloth, clean all the rubber rollers on the bars. Cheap paper leaves a fine dust and after time will make the wheels very slick.
Doing this every other month can save you from jams and is just a good maintenance plan for your printer.
Also don't use 'cheap paper'.
Good luck! :)
Oct 26, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Paper jam
Ensure all paper pieces have been removed, you might have damaged some circuits or wiring. If still do not want to power-on take to vendor.
Apr 19, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
273 people viewed this question
Seeker5211
Seeker5211
