I get a red/blue/green static at the top of my plasma tv.. when the picture goes to a dark color its usually speckles red.. then when its a light color it doesnt really show.. wats the problem?
    President:
  • 1,284 Answers
In some cases it is just a matter of making voltage adjustments on a plasma set to get rid of the spots you are seeing. I would look for a reputable technician in your area to see if this is the case. Good luck...
Posted on Nov 19, 2008
    Scholar:
  • 146 Answers
I have seen this before, it is either the panel driver pcb or the panel itself. Not all manufacters sell the driver pcb by itself. So you have to repalce the panel anyway. The panel will cost you more than the cost of a new tv. So you need to buy a new tv. Sorry for the bad news.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Color Speckling in Dark Part of Picture
the set needs to have an adjustment in the panel voltages. this must be done by a qualified tech. the panel has now gotten it's full aging and now needs to be adjusted. this adjustment does not need to be adjusted again after this has been done.
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Colorful "speckles" on screen
Could be the screen burn from watching T.V. on a show and the thing burnt in (in this case the colors, yes it can burn colors.) and there's nothing you can do. The insides of the T.V.'s have plasma gases which can flow out of control.
Jan 14, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Plasma HD TV Picture blue color static
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
Lg42px52 speckling.
The speckling is caused by the CTRL board. The firmware needs to be updated. Unfortunately LG does not provide a media slot for downloaded upgrades. You must order an install the factory updated CTRL board located between the power and the Y sustain boards.
Nov 24, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
