Question about Canon PIXMA iP4200 InkJet Photo Printer
Paper jam- canon iP4200
Hi! Hope you can help!
I would like to know how to clear a paper jam. Usually it is at the front, this time, at the back- can just about see the edge of paper, but to little to pull out.
The manual I have says remove rear cover [which I did] and then to removing 'cassette' which I cannot identify [as it says it is in the user manual which I do not have]. Please help!
Thanks
  • 20 Answers
Here is the repair manual. It covers everything involved in repairing the printer.
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Posted on Nov 19, 2008
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
SERVICE ERROR 6A00
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 14, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error number 6A00 for Canon Pixma IP4200 Blinking Power and resume light.
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Feb 02, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error Message 6A00 ??
Hello there here is the codes
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 09, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Service error 6A00 cancel printing and turn on the printer off and back on. If doesn't clear the error, see the printer manual for more details.
Hi
Can gave it a go
Solution 1:
Solution 2:
Solution 3:
Dec 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Please problem solve
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon mp180 paper jammed
I finally fixed the problem by running two sheets of heavy card stock through at the same time. With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor. I previously found that only one sheet at a time did't work.
I found this solution posted by JsamJr answering another question but it worked for me. pushing the card in and then removing it and pressing ok worked
Mar 24, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
I had a paper jam in my ip4200.
Make sure the paper ways are clear of bits of paper- a vacuum cleaner hose? Also look in on www.fixyourtownprinter.com
Jun 01, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
416 people viewed this question
old marine
old marine
