Question about HP Office Equipment & Supplies
My printer keeps telling me I have a paper jam there is not
  • 95 Answers
There is no doubt if we try to follow our experts to solved your particular problem.
Paper jams doesnot only the problem that can be happen in any printer.
Just follow the simple instruction that will appear on your window screen because it's the best thing
that will work out in trouble shooting problems.
If not call service center nearest you.
Posted on Nov 21, 2008
    Scholar:
  • 57 Answers
Agreed - a model number would be more helpful.
But, often times, there can be a little tiny piece of paper or sticky piece of label paper that has gotten wrapped around the roller somewhere. Take the back off and make sure there isn't a shred of something left over from some previous jam.
If you don't see anything, lift up the lid and make sure there isn't a scrap of paper somewhere inside that keeps taking a ride on new pieces of paper, enough to trigger the error message.
Of course, I am assuming you have already tried this, but just in case...
unplug the computer and leave it unplugged for a few minutes. Reboot your computer.
Then plug the printer back in. It could trigger a reset in whatever gave the original jam message.
If that doesn't do it, then you might have a bad sensor. Again, model number would have to be included to be more specific.
Posted on Nov 20, 2008
  • 36 Answers
Dear kazatkins
Usually when this problem appears it has a sheet of paper wrapped around the heat roll of the fuser. Open the back of the printer, you should see a black roll and an orange roll (could also be 2 black rolls). If one of the rolls is white you have paper wrapped around it.
The next thing that tends to cause this problem is the exit sensor for the fuser is broken or out of place.
Just use a slightly damp cloth or some sort of disposable towel and clean the printer.
Posted on Nov 19, 2008
  • 89 Answers
There is either a sensor flag out of place, which is usually a small plastic piece, or you still have a small piece of paper stuck some where. Without knowing which machine we are talking about it's hard to say which it is.
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam
Refer to www.kodak.com/go/itg and select all in one printers and then paper-jam . it will step by step show you on how to remove the paper-jam. if the printer does not work,after those steps Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.
Jun 28, 2009 | Kodak ESP 5 Printer
Printer keeps telling me that theres a paper jam but theres not
A small piece of paper is probably covering a sensor. Get a torch and dive in there.. have a good look
Apr 23, 2009 | HP Officejet 4315 All-in-One Printer
Paper Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
215 people viewed this question
Ben Johnson
