My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Posted on Nov 18, 2008
It wont stay on
Is it turning off with charger connected or without charger?
If it is turning off while charging also, Try doing a soft reset.
  1. Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
  2. Hold until the player shuts down.
  3. Power on the player again by using the Power on/off key.
If this doesn't help, try repair it using Philips device manager program which came with the CD or downloadable from Philips web.
Apr 19, 2014 | Philips GOGEAR SA6045 MP3 Player
2000 jeep Cherokee sometimes runs fine shut it off wont start but turns over fine later it will start
Ok. You didn't say what size engine was in the Jeep, but based on your problem, I'd bet its the 2.5L 4 cylinder. They had a classic issue with intermittent failure of the crankshaft sensor. This will cause the vehicle to just shut down without any other indications, Sometimes it will restart immediately, sometimes it can take minutes to hours to restart. The sensor is easy to replace and not very expensive. It is located on the drivers side of the transmission bell housing.
Nov 04, 2013 | 1998 Jeep Cherokee
Hello my laptop philips freevents h12y i need audio driver win7
Hi shulalbvvc, "Go to this "Website!"
It shows 'all the Audio Drives for the "Philips Freevents H12Y!"
Scroll down to find:
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.search.philips.com/search/search?h=support&o=support&q=Audio+Drivers+Windows+7+philips+freevents+h12y&f=all&i=all&language=&l=us_en&s=all&n=10&d=&p=&p_fld=&p_val=&highlighted_param_entry=¶m_group=¶m_group_value=&first=&last=&next_start_hit=11&bannercount=0
Mar 16, 2011 | Computers & Internet
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
I need to obtain a free down load of the instruction manual for a philips freevents lx2000 mini pc
Hi friend, please follow the link provided below just click on it or copy and paste in your address bar.
http://www.user-guides.co.uk/download/instruction/instructionmanual/instruction-manual-philips-freevents-lx2000-mini-pc.html
Please get your manual from here.
I hope this will help you. Plz vote Thanks.
Sep 24, 2009 | Philips Televison & Video
Recovery disk for Philips Freevents and system running slow
Readthis thread before you attempt anything.
http://lofi-gaming.org.uk/blog/2008/02/29/how-to-install-xp-on-a-philips-freevents-11nb5800-laptop/
Aug 02, 2009 | Computers & Internet
Philips Freevents X50 charging problems
well my friend I hate to say this but the problem is in the motherboard, and the motherboard should be replaced.
Jun 27, 2009 | Computers & Internet
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Shutsoff, stays off problem...
Get the updated verison of the Philips Device Manager from Philips website, and then click on the Update button once you have installed the new Device Manager.
Several things to be wary of:
* a Philips player ending in "/02" is designed for use outside of the United States
* the SA5125 is incompatible with Windows Vista and Windows Media Player 11 without a firmware upgrade
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
Tv turns on but wont stay on
There is a resistor on the CRT board that goes bad sometimes. I cannot remember the number but it is a common fault as the TV starts up and then detects too much beam current and shuts back down. If you have a multimeter, you can check the resistors if you know how the color coding works on these resistors. If you do not, take the set to a repair shop, as this problem, if this is the problem, should not cost that much to replace a 10 cent resistor. Good Luck
Jun 12, 2007 | Philips 32PT6441/37 32" TV
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
