Question about IBM DPS-185DB (DPS185DB) Power Supply
Is ther any power suply that i can use instead of my original one
My power suply is gone and i am wondering if there is a way to replace it with a simple one
Andre christopher coa cool how is computer my son danil jason de-cos-ta cool thank you good keep up the good work.
Posted on Apr 30, 2012
  • 624 Answers
Its physically different shape will probably require you to modify your case to accept a conventional power supply. Just did a quick search and found an Ebay active sale and an on-line store that had your power supply for a reasonable amount. That might be a more reasonable alternative for you. Ebay: http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R10&satitle=power+supply+dps+185db&sacat=3666%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=14850&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp= Other guy: http://affordablesurplus.com/delta-dps-185db-a-power-supply.asp
Posted on Dec 07, 2006
Haw to fix this tv power suply
Fixing power supply problems is a skilled work. It will be not so easy for a newbie; and will be dangerous to him/her too. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 01, 2013 | Soyo Televison & Video
I have a samsung monitor SyncMaster93DF it stopped completly with a little sound (tick tick ) i oppened it and found the hot transistor shorted (st2310) i replaced it with bu2527 because i couldnt find the...
try C5804 or J6812 instead of bu2527..replace IRF630 in 50 volt supply line.it may b faulty...bt if problem after that then flyback transformer may b faulty. repalce it with same one.
Sep 05, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Hose keeps bursting about 3 in from outlet. It has a cutoff at 125 lbs. Is ther any way to resrt pressure?
yes under the power suply ther should be a bolt with + - ether side + give it a turn ether way in your case decress -
Jul 11, 2010 | Air Tools & Compressors
Power suply the computer wont turn on
the smos of the comp might have gone bad
Feb 07, 2010 | E-Machines eMachines Desktop PC
No 6V power via power adapter to Sony ICF-SW7600GR
Could be a diode or a capacitor. Where are you located?
Feb 07, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Powers down
get a bigger power supply
Jul 29, 2009 | Alpine CDE-7826P
Error message-machine errror 6c
Actualy the fuser has overheated and as a result probably has died.
the best thing to do is to replace the fuser and power suply (probably there is a short in the fuser drive thyristor causing the fuser to have been overheated).
After replacement of fuser and power suply you should reset the fault in service mode by doing the following:
1- press the Menu button,*, 2, 8, 6, and 4 keys in this order within 2 seconds.
2- press the keys 9 and 1 in this order to clear nv-ram
3- after nvr-init is done press key 9 twice to exit maintenance mode
4- power the printer off and on.
Aug 08, 2008 | Brother MFC-8640D Printer
Dont Post
I thunk your rite it met its maker, sounds like you followed all the test procedures, and unfortanuly that's what happens from time to time working great on min then gone to the GB in the sky the next. unless you have a DX card or know someone that has one, (and thats only to confirm its dead) sounds like you need a new system board.
Nov 20, 2006 | Acer AOpen AX4BS-V (91.89J11.001)...
Computers & Internet Logo
359 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
