Question about Kenwood KAC-9102D Car Audio Amplifier
Will they work together?
Will the 1800watt Kenwood Amp and the 1700 watt Kenwood work together in their joining way?
  • 62 Answers
I believe the models need to be the same in order to work together. They will work together but just how good is unkown till your try it.
Posted on Mar 26, 2007
I have a 300 watt alpine 4 channel amp powering 4 x 6.5" kenwood speakers. My speakers can take up to 170 watts each. I have to turn my gain up all the way on my amp in order to get a quality bass...
Your amp is overheating as your speakers all combined are 680 watts, double your max output on your amp. Ideally you need a 1000 watt amp to do the job and for perfect sound as you should never have your amp up to max as it is more likely to blow quicker. The 2000 watt amp your are speaking of will do the job perfect, but you need to keep the gain down around 50% as you could blow your speakers. But yeah all together you are right, the 2000 watt amp will stay cool as doesnt have to work nowhere near as hard as the one you have currently.
Mar 02, 2011 | Alpine Car Audio & Video
How should i have my 4ohm single voice coil JL audio 12in subs connected to my kenwood kac-9104d 1800 watt max power (500x1 @4) amplifier?
On the outputs of the amp there is:
1 2 3 4
terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Feb 21, 2011 | Kenwood KAC-9104D Car Audio Amplifier
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Subs not programmed into dash...?
It sounds like the input gain on the amplifier needs to be adjusted.
OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Searching for the right amp
a kenwood 1800watt d class mono block cost ruffly $600
Oct 04, 2008 | MA Audio HK15X2 Car Subwoofer
Sub problem
have u tried bridging the speaker wires. amp could be gone?
May 19, 2008 | 2002 Pontiac Grand Prix
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
