Question about Compaq Presario 2135US PC Notebook
Pcmcia slot not recognizing pcmcia card, where as it is working on other laptops
    Guru:
  • 257 Answers
If thats the case that the pcmci is working on other laptop but is not working on your laptop thats there is a fault within your Pcmci slot is faulty and what you will have to do is that if there is still one more place for you to slot the Pcmci then do that but if there is not then you will have to find a pcmci that will be USB then you can be using that for the main time before you desold the pcmci slot away from the laptop and resold a new one for proper functioning ok .thanks
Rate this solution .
Posted on Nov 18, 2008
I own a Dell Latitude C610, how do i upgrade my usb 1.1 to 2.0? if i need any hardware can you please provide me with a link?
you will need to purchase a usb 2.0 pcmcia card.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=USB+2.0+PCMCIA+card&x=0&y=0
May 27, 2011 | Dell Latitude C610 Notebook
A distorted sound is coming from my speakers even if i connect speakers
It is a possibility that you are getting feedback from a device that is near by. Possibly a cell phone or other device. I would recommend moving the computer to a different location and removing all electronic devices from beside the computer, then reconnecting speakers.
It is also possible that you have a bad sound card. If that is the case, you will need to purchase another sound card and replace the old one. I have included instructions on how to replace your sound card below:
Here is a site where you can purchase the sound card you may be in need of:
http://www.meritline.com/laptop-sound-card-usb-port---p-39078.aspx?source=nextaghdac
There are other sites such as Ebay where you can also purchase the sound card. The type of sound card you need is a PCMCIA Sound Card for an Acer Laptop.
Here are instructions on how to install a new sound card:
    Installing a PCMCIA Sound Card in Your Acer Laptop
  1. Step 1 Locate the PCMCIA card slot on your computer. On an Acer laptop, the slot may be either on the left or the right side of the laptop.
  2. Step 2 Remove the PCMCIA card cover by pressing the "Eject" button and pulling the cover out.
  3. Step 3 Insert your PCMCIA sound card with the connectors facing in and the upper label facing up. Some PCMCIA cards will have an arrow to make it easier to orient the card correctly.
  4. Step 4 Press the PCMCIA card gently into place.
  5. Step 5 Windows will recognize the PCMCIA card and search for the needed software.
  6. Step 6 If your sound card came with an installation CD, insert it in the CD slot and follow the instructions to install applications and utilities for use with your new sound card.
    Installing a USB Sound Card in Your Acer Laptop
  7. Step 1 Turn the computer on.
  8. Step 2 Plug the USB sound card into the appropriate USB plug on your laptop.
  9. Step 3 Wait for the computer to recognize the new USB device.
  10. Step 4 Insert the sound card manufacturer's CD if prompted to do so.
If a sound card is not the issue, then you possibly have circuitry issues on your laptop motherboard. For this issue, you may need to consult a certified technician at your local computer repair shop.
(If you are not a professional or are used to opening your laptop, I would recommend taking it to a local computer repair shop for a certified technician to look at this issue. Do bare in mind if you have a warranty, opening your laptop and not being a certified professional would void any warranty agreement you have with your manufacturer)
Jan 08, 2010 | Acer Aspire 3000 Notebook
Can u install afire wire card into a compaq presario c700
Yes, but it needs to be a Firewire PCMCIA card. If you do not have a spare PCMCIA slot then you need to remove the other PCMCIA device so you can insert the Firewire PCMCIA card when you need it.
Oct 20, 2009 | Compaq Presario 700 470024-192 Notebook
Where do I insert the Dynex card?
You insert the dynex pcmcia network card in a pcmcia slot, if your laptop has one.
If you don't find a place you can insert insert the card, that means that probably your laptopt does not have a pcmcia slot; maybe it gas a exopress card slot, smaller and more frequent in recent laptops.
Aug 06, 2009 | Dynex 802.11g Wireless-G Laptop Card
Type II PC Card Slot does not work
Probably the drivers are missing. Go to Start, Control Panel,Syatem, Hardware, Device Manager. There should be a line that says PCMCIA adapters. If it has a red or yellow check mark then the drivers are faulty. If it's not there the drivers are missing. Download a new set of drivers from support.dell.com.
Apr 02, 2009 | Dell Latitude D620 Notebook
What type of pcmcia slot is on the hp pavilion dv6000.?
Most laptops have Type II PCMCIA slots. Some laptops have one slot, others have two slots. For details read the following :-
  • Type I cards can be up to 3.3 mm thick, and are used primarily for adding additional ROM or RAM to a computer.
    • Type II cards can be up to 5.5 mm thick. These cards are often used for modem and fax modem cards.
  • Type III cards can be up to 10.5 mm thick, which is sufficiently large for portable disk drives. As with the cards, PCMCIA slots also come in three sizes:
  • A Type I slot can hold one Type I card
    • A Type II slot can hold one Type II card or one Type I card
  • A Type III slot can hold one Type III card or any combination of two Type I or II cards.
  • Mar 31, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
    Verizon Wireless PC 5750 air car work in a HP Pavillion
    No because the Aircard PC5750 is a PCMCIA slot card, and your laptop has a Next Gen Express Card/ 54 Slot. The Express card slot is smaller than the PCMCIA slot. That makes the PC5750 incompatible.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Dec 20, 2008 | HP Pavilion dv6000z Notebook
    Pcmcia dont work
    Unplug the card from the slot and reboot your laptop without it in there. After your computer boots back up, plug your card back in and it should recognize it again.
    Jan 21, 2008 | Zyxel ZyAIR B-5000 802.11b (zyairb5000)...
    Techgear 3-port 1394 FireWire CardBus
    Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
    Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
    Compaq Presario 2135US PC Notebook Logo
    188 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
