Question about Minolta magicolor 2350 Laser Printer
Minolta EN 2350 is not printing. Printer Display reads Processin
I'm using a Mac G5 duo on OSx. I am connected to the printer via USB.  At first, my problem was with connection using USB.  Now it seems that the USB is connected. I see the printer in the printer queue.  When I send to print. The printer stays processing forever even when printing a test page with one word.
Is there a setting on the printer that I might have selected to cause this problem?  I've done the reinstall of driver already.  Your input might get me to start printing again.
  • Minolta Master
  • 6,359 Answers
IN PROCESSING mean its doing the internal house keeping are your image units and toner OEM no other error code, reseat all the toner and image units, Replace non OEM Cart. try this site for latest drivers etc.
Self Help Product Support Konica Minolta Business Solutions Inc
Posted on Dec 26, 2015
  • 300 Answers
SOURCE: konica minolta opc drum magicolor
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
Posted on Jun 15, 2008
SOURCE: question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Posted on Nov 19, 2008
SOURCE: Konika Minolta 2400W can not connect. Clearly
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Posted on Jul 19, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Di351f. Can not print over the network.
I am confused. If you can see the printer via the web browser and you can print a window's test page you are all set up and ready to print. There should be no problem printing as long as you have that printer selected as the default printer and it is selected in whatever program you are printing from. What do you mean by "straight over the network"
Posted on Dec 22, 2009
Testimonial: "This was helpful because I got the printer working. I made me take another look at the installation and enter the right settings and port number in."
  • 857 Answers
SOURCE: My magicolor 2350 printer states
The printer uses an "eye" to check the level of toner. You can override this. Open the front door of the printer and take out the cartridge. There is a small round "window" (less than 1/4" in diameter) about halfway along on the right hand side of the cartridge. Stick a small bit of black insulation tape (or scotch tape colored black with a permanent marker) over the window and pop back into the printer. When you turn the printer on, it won't even give that "Cyan toner low" message!
Posted on Sep 29, 2010
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Printer Problem: Epson Stylus Photo R340. Hello, I upgraded my IMac G5 Intel Core Duo to Snow Leopard Version 10.6.8, and now when I try and print pages I get an error message - Error:...
HI, That's error need software driver reinstall. to download software driver for Mac operating system click the following link http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=60586&prodoid=58654762&infoType=Downloads&platform=Macintosh If finish downloading, double click software driver. just read software instruction step by step installation guide.
Hope can help you. Regards.
Jul 10, 2011 | Epson Stylus Photo R340 InkJet Printer
I upgraded my Mac mini to Snow Leopard OSX 10.6.2. Reloaded the printer software but the printer wont print. THe printer is connected via USB. When I send a document it shows error on the printer queue....
HP PSC 1610 All-In-One InkJet Printer Printer HP PSC 1610 always printed till I... Answer I think I have a similar problem:HP PSC 1610 always printed till I installed Mac OS X 10.6. also does not digitalize since I downloaded: HP_Installer_PSC1600_v9.7 An error apears about a missing extention ? ? ? ? Carlos Moniz
Feb 02, 2010 | HP PSC 1610 All-In-One InkJet Printer
When there is a site I log into if on my mac OSX 10.5 4 even though a USB cord is connected and the wireless light is on when I press file on the Mac and go to print the HP J4680 does not print what is ...
1. click a text file to print
2.on the drop down menu for printer select printer (there may several listed)
3.if printer not shown then click "add printer"
4.locate your printer model and install
5. This may require you to go to the manufacturer site to download the updated drivers.
6. check the Printer installation manual for step by step instructions
Located on the CD that came with the printer.
Sep 29, 2009 | Apple MacBook Pro Laptop Computer with...
How do I install the rocketfish camera on a mac? My computer can not read or open the files on the installation CD. Any suggestion?
http://www.rocketfishproducts.com/pc-35-3-rocketfish-notebook-web-camera.aspx
download the installation from here. it should work if the computer answers these requirements:
G3, G4, G5 or Intel Core Duo based Mac.
USB 1.1 or higher port
MAX OSX 10.2.0 or higher
QuickTime version 6.5.1 or higher
Sep 24, 2009 | Logitech QuickCam Connect Webcam
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Mar 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer Busy message
check your mac connection settings, change if needed, try install new printer.
Dec 07, 2007 | Konica Minolta bizhub C250 All-In-One...
Minolta magicolor 2350 Laser Printer Logo
83 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
